Ive just bought myself a Toshiba 36ZT29B.
Here is a good site with the specifications.
http://www.ciao.co.uk/Productinforma...T29B__5338246/
As it says, it has progressive scan. and it says right on the front of the TV too.
Now, Ive got a PS2 and Gamecube, which obviously use progressive scan too. But everytime I try to use the progressive scan, the TV just goes blank, ( blue is the blank colour for my tv ).
The cables Ive tried to use on my TV are:
A normal scart ps2 lead into the "scart" which says 1 x SCART (RGB) ( 21 PIN SCART ) - rear. That doesnt work. Which I kow shouldn’t.
Well the Gamecube one I cant find on the net I bought, cost me about £40 Its got 2 things that plug into the Gamecube 1 purple cable and 1 black and they connect with each other, making 1 purple scart head. Supposedly for pal gamcubes. That doesn’t work either. This makes the picture better, but I also lose my surround sound which are connected into my tv.
When I plug my red/yellow/white sockets from my Gamecube into the side of my TV, the picture is ok, not as good as the RGB scart, or my normal scart, but I get the proper surround sound.
Then I have this cable, which has the connecting part to the xbox, ps2 and Gamecube, then a little box, which switches from av-to rgb and then the scart head for the consoles, and a red, yellow white thing. While that makes the picture better for my normal tv, playing import games, it doesn’t fix the progressive sound, and also I lose my surround sound.
So I was wondering, what cables do I need to get progressive scan on my PS2 and Gamecube, and also xbox and dvd player. I use it mainly for import Japanese and US games.
Will it be cables like these:
http://www.lik-sang.com/info.php?cat...ducts_id=1696&
http://www.lik-sang.com/info.php?cat...oducts_id=266&
I don’t think this 1 will work
https://www.consolesandgadgets.com/c...95b5193fd03220
Lik-sang said this is for the pc monitors. And also gave me this message:
Basically, just connect your DVD with the RGB scart cable and activate
progressive scan mode, and you should be fine.
http://www.lik-sang.com/info.php?cat...ducts_id=1468&
I think this might work, but cant seem to find a ps2 version.
http://www.consolesandgadgets.com/ca...95b5193fd03220
Im very worried I cant get my progressive scan on my TV. It says progressive scan, and it should work. Is there anything like an all in 1, for all my consoles?
Thank you very much, sorry for the long message.
Pease please help me.
sorry about posting this thread in 3 different boards here.
Thank you
Kourosh
