20-09-2005, 9:53 AM
#1 (permalink)
| | Guest | 28" or 32" CRT with 480p
hi all,
Well after my debacle with the samsung slimfit, i've decided to go through the hassle of trying to return it. The geometry probs are just too awful. I'm now looking for a replacement & decided that I'll leave true HD for a while.
I need a few suggestions please, as it looks like I may be locked into getting the replacement from the original suppliers of the slimfit. £500ish is my budget. All I want is a good picture with no wobbly lines & a 480p input.
Please help a distressed man!!
Many thanks,
PMF
20-09-2005, 10:14 AM
#2 (permalink)
| | Prominent Member
Thanks: Gave 96, Got 151 |
I have the 32ZP48 Toshiba and it has 480p component and is exellent.PQ for both sky/dvd/xbox is very good and you can get it for around £500 or maybe even less now due to the hard hitters on the market.
If you want a larger screen the 36" is equally impressive and features a geometry service menu so if you do have any wobbly problems,it can be fixed.My 32" has a little geometry problem at the edge of the screen but is hardly noticable,its not noticable in 16:9 at all.
The sound is exellent aswell considering the 4 outer speakers look cheap and plasticy on first glance,but give out a deep and crisp sound with good depth.
Oh and the stand is awesome |
20-09-2005, 6:54 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 47, Got 106 |
Your not alone with the Samsung and it's problems. It recently had a review in some certain mag and got a BIG thumbs down due to it's geometry problems and apparently to compensate for it's reduced rear it uses larger pixels at it's edges!
21-09-2005, 9:24 PM
#4 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Bets prices for 32ZP48 Quote: |
Originally Posted by stuart69 I have the 32ZP48 Toshiba and it has 480p component and is exellent.PQ for both sky/dvd/xbox is very good and you can get it for around £500 or maybe even less now due to the hard hitters on the market.
: | Hi,
Having pretty much settled on this set after viewing LCDs and deciding maybe they weren't for me yet, the best price I can find is around £625 delivered, have you a link for anything lower?
Regards
Wooky
21-09-2005, 10:01 PM
#5 (permalink)
| | Senior Member
Thanks: Gave 47, Got 106 | www.mkatv.com
£549 + £60 delivery! Make sure it's brand spanking new tho' as they sell factory refurbs too.
21-09-2005, 11:04 PM
#6 (permalink)
| | Senior Member
Thanks: Gave 18, Got 50 |
I too can recommend the Tosh 32zp48.
PQ from my Pioneer 575 in prog scan is great, sound is more than good enough (DD and PRO-LOGIC), even tho' I rarely use the on-board speakers due to a full compliment of AV reciever, seven speakers, plus two sub's  .
I too have a slight problem with geometry, but TBH it's very slight so I can't grumble at it, heck the PQ makes up for it anyways, (plus it's gotta be better than the Sammy after what I read in "THAT" review IMHO).
All digitally "filmed" fodder (Incredibles, Toy story, Shrek etc etc) on DVD looks absolutely A+++ but remember to set the picture (colour, contrast etc) from the factory settings as these are WAAAAY OTT, (100% contrast for a start  ).
Also it has three scart sockets :- (two rgb, one switchable for composite/s-vid), component sockets (PAL & NTSC prog-scan enabled), and as a last resort, composite under the front mounted flap, so connectivity is up to scratch for the majority of users.
All in all, I am very pleased with it although initially, when it was delivered I thought it was a 28" screen as it considerably narrower that the Philips 32" I had previously, so it is ideal for those who are short on space (width ways), it still has a bloody great big arse sticking out the back tho'..  ..
TTFN,
Graham.
__________________ LOUNGE SYSTEM.Samsung LE46A656.Sony BDP-S550.Denon AVR 2808.Monitor Audio BR2-AV+BR1 surround rears.BK XLS200DF.Humax 9200T.60Gb PS3.Harmony 885 URC.
BEDROOM SYSTEM.Samsung LE32R87.Yamaha DSP-AX861SE.Denon DVD1930.Tannoy EFX 5.1.PC. |
22-09-2005, 8:37 AM
#7 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Quote: |
Originally Posted by per-Sony-fied www.mkatv.com
£549 + £60 delivery! Make sure it's brand spanking new tho' as they sell factory refurbs too. | Thanks for the link, and thanks for the warning about refurbs.
Wooky42
22-09-2005, 8:57 AM
#8 (permalink)
| | New Member
TTFN,
Graham. | I'm on the brink . . . !!!
What's holding me back is the Samsung 28" or 32" LCDs. I saw the 28" in Comet and they were playing Shrek from a (bit hazy here) Panasonic DVD/Dolby system (£399), connected by component, switching the DVD in and out of component I couln't see a change however, and it was the most stunning picture I have ever seen, I just can't believe a CRT can approach that.
They also were playing a hi def feed through a 32" Samsung LCD and when the Football section came on it was shocking, unwatchable, juddering and blurry.
In the display area of Currys they had video feeds going into some LCDs and true to what I've read here, the LCDs were not flattered by it, while the CRTs make the most of it.
A guy in our village gave me a DVD of a villlage event to duplicate. I watched it on my Panny DVD recorder on a 14" CRT and it was fine. I then played it on my MCE machine through a 17" TFT and it was shocking, at that point you could see that it was mastered on a VHS.
I'm rambling but, the point is, because of the above I don't know which way to Jump, I use SKY, SKY+ an MCE and a modified xbox for XBMC. It's a fair amount of money and I want to jump the right way!
Wooky
22-09-2005, 10:56 AM
#9 (permalink)
| | Guest |
Wooky im in exactly the same boat mate. I was hoping to get some high def future proofing in, but it just seems that it's not worth it at this stage. If we we're buying in the middle of next year when SKYHD is bedded in then we'd have a lot better idea of what to get & prices would be cheaper too. Also we have no idea how much SKYHD is gonna cost.
At the moment, I'm all over the place. I need my football to be watchable & I'm just not convinced by LCD on that score. Plasmas are too expensive (for me at least). I also love my XBMC & wanted prog scan for that. But its £600 for a decent set with 480p, which is a lot of money really, when LCD's are just £200 more & have high def.
At the moment I'm thinking of just spending £200 on something to last me a year or two & then get a proper set, when it's all a lot clearer & there might be better sets on the market.
I'm still a little tempted by the Tosh tho, arrrrgggghhh!!!!!
PMF
22-09-2005, 11:28 AM
#10 (permalink)
| | New Member
<snip>
PMF | Or you could say you're getting a top of the range(ish) CRT for £549 plus del, or a bottom of the range 32" LCD for £250 more! I reckon you've got to pay well over a grand for a decent 32" LCD with better processing power inside it.
But it's a worry as prices tumble and specs raise . . .
Wooky
22-09-2005, 3:25 PM
#11 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Bit the Bullet! Quote: |
£549 + £60 delivery! Make sure it's brand spanking new tho' as they sell factory refurbs too. | Well, enough dilly dallying, I ordered one from those guys, arrives Saturday on a pallet!
Wooky
23-09-2005, 9:06 AM
#12 (permalink)
| | Member
Thanks: Gave 12, Got 5 | Quote: |
£549 + £60 delivery! Make sure it's brand spanking new tho' as they sell factory refurbs too. | Typical, i paid £575 in August although as i live in the same town didn't have to pay delivery. Aside from a minor geometry problem i am impressed with this TV. |
