Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
HTPC / MCE and Sky *Set-up* DoblANy Windows Media Center Edition MCE 8 25-05-2005 4:04 PM
PD50 problem with 480p PUD the Ancient CRT Televisions 13 15-01-2005 11:36 AM
576p or 480p? Gene Projectors 5 22-08-2004 10:50 PM
AE-100, Nintaus N9769 & HTPC. Comparison tests. Kramer Projectors 16 10-04-2003 11:22 PM
HTPC resolution and picture size mjwhitehouse Computer Systems 11 09-08-2001 4:30 PM
Old 19-09-2005, 2:09 PM   #1 (permalink)
Thanks: Gave 3, Got 0
HTPC to PD50 480P 576P resolution
Not sure if this is the correct forum but here goes.
I have a media cetre PC connected to a TX-32 PD50 via components inputs using a ATI 9600 and component dongle.
I am using power strip and am trying to create the highest supported resolution to no avail.
I can get 640x480 to work OK but not 720x480 which I assume is widescreen version.
Knowing the PD50 supports 576 progessive scan I would rather use that but cannot get any of the custom resolutions with 576 to work.
What resolution and refresh rate is 576P anyway?
Does anyone have a custom powerstrip code for the PD50?
benbtg is offline   Reply With Quote
Old 19-09-2005, 6:45 PM   #2 (permalink)
576 is 720 x 576. I can achieve this resolution at 50 or 60hz with my nvidia card using s-video. 720 x 480 or 720 x 576 although are widescreen resolutions will appear streched on a 16:9 TV because your computer thinks it is outputiting to a 4:3 monitor. I am sure Powerstrip can adjust this but I use Zoom player for DVD and avi playback it can adjust the aspect ratio to suit.
I do not use Powerstrip but I have read much about it and it is not just a case of adjusting refresh rate. There are many other settings but I think it should have default settings for your needs.
0lly is offline   Reply With Quote
Old 19-09-2005, 8:12 PM   #3 (permalink)
Thanks: Gave 7, Got 16
erm my 10 yearold tosh 21" set can display 720x576 not a problem through composite
mcbunny is offline   Reply With Quote
Old 20-09-2005, 9:30 AM   #4 (permalink)
Yes but this is through component which produces a much crisper picture then through composite or svideo. It also accepts progressive scan (i.e. not interlaced) which further enhances the picture.
I have had no problem using resolutions upto 1024 768 on svideo and composite, but the picture is so blurred (even at 720 576) as to be unusable. Having seen video through component connections I would never go back. Problem is the TV is very picky about the exact resolution and timings used. So far I have only been able to get 640 480 to be work, which although very crisp picture is still quite low res.
Does anybody with a PD50 have it hooked up to a PC via componets video?
480p, 576p, htpc, pd50, resolution
