Hi guys,
Another 32ZP48p owner here !! Just to reiterate whats been said already, once adjusted to a more realistic level, the PQ is great.
Contrast, brightness, colour etc etc are set WAAAAY TOO HIGH from the factory, take the time to calibrate it and the difference is like night and day.
DVD PQ using prog-scan IMHO is faultless, freeview thru RGB is better that terrestrial off air broadcasts.
All in all, I am more than happy with it. I dont have the supplied speakers connected up (see sig below as to why), but needless to say the sound from its in-built speakers / subwoofer in stereo is about the best I've heard from a TV. The supplied satellite speakers are a bit "plasticky", but give a decent enough spread of as sound I found upon a quick test of the TV upon its arrival at the Jones' residence. You can always upgrade the 4 sat's if you find they aren't enough for your needs easily enough with some small bookshelf speakers. I used a pair of
THESE on the front channels and found them a lot better so I suppose 2 pairs used for fronts and rears should be a cheap alternative for an upgrade ??
As has been said, geometry is a bit of a problem, but using the details found
HERE you can iron out most (if any) probs you have. (dont worry about the model No's shown, it does work on the ZP48's). Just take the time to take down ALL the origonal settings first. Also, when in the service menu (accessed by pressing MUTE on the remote once, then press and hold MUTE on the remote and MENU on the TV's control panel under the front flap at the same time), if you press the AV input button on the remote you can scroll thru a red, green and blue screen to a white and black grid that can be used to make adjustments to the geometry if required.
All the best,
Graham.
