Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 18-09-2005, 6:58 AM   #1 (permalink)
Thanks: Gave 3, Got 0
CONNECTING 3 TVs TO ONE AERIAL
Not sure this is in the correct category so here goes.
I'm trying to connect 3 tvs ( one Panny 32PD50 and two portables) to one roof mounted aerial. As expected, the signal to each has now degraded.
Are aerial boosters any good? If so can someone recommend a good one?
What other options do I have other than paying someone to put another aerial on my roof?
As an alternative, can I put some sort of smaller aerial in my loft?
Thank you for your help
Trickdick is offline   Reply With Quote
Old 18-09-2005, 7:54 AM   #2 (permalink)
Thanks: Gave 0, Got 7
I myself would always recommend a new aerial fitted by a pro, bear in mind analogue will be switched off within 5 yrs depending on your location. So think long term.
If you try a booster/amplifier it is better placed as close to the aerial as possible.
Do you have a good receptoion on the first TV?
If not, it would be usless trying to boost a poor signal for 3 TVs, boosting relys on boosting a clean signal, if you boost interferance also, it is usless.
Nigel
nig28 is offline   Reply With Quote
Old 18-09-2005, 11:06 AM   #3 (permalink)
Thanks: Gave 51, Got 480
In addition to the signal problems mentioned above, connecting three TVs together directly via their aerial cables is a bad idea from a safety point of view. If one of them has any sort of insulation fault leading to any nasty voltages appearing at the aerial socket, it could damage the other sets.
GaryB is offline   Reply With Quote
aerial, connecting, tvs
