Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 16-09-2005, 2:06 PM   #1 (permalink)
Richer Sounds told me i could use co-ax for components?
I have a 32zp46 and a sony davs 550 with component out.
I've been looking for a component cable, went to RS and they had run out......he said instead i could buy 3 x Coax cables (you know the ones to connect the dvd to your amp) to give the signal instead - i'm fairly certain this would not give optimum picture clarity - can anyone confirm?
Is Richer Sounds giving wrong advice?? (Bearing in mind it was £10 more to do it this way as well!?)
Neil
Neiliboy is offline   Reply With Quote
Old 16-09-2005, 5:11 PM   #2 (permalink)
Thanks: Gave 37, Got 256
Just buy two 99p audio phono cables, it will work as well as any other cable.
The best argument against democracy is a five-minute conversation with the average voter.
pjclark1 is offline   Reply With Quote
Old 16-09-2005, 8:13 PM   #3 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
As long as they are nice and thick they'll work fine.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 16-09-2005, 8:16 PM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
As long as they are nice and thick you won't notice any difference and they'll wok fine.
JayCee
Old 17-09-2005, 11:20 AM   #5 (permalink)
sure i read something about picture signals requiing a a higher ohm rate or something.....or am i just imagining it?
Old 19-09-2005, 12:31 PM   #6 (permalink)
Astaroth's Avatar
Thanks: Gave 18, Got 70
component is designed to go along a 75 ohm cable. What "quality" of cable you need is something that is hotly contested with those who think that as long as the cable is thick it is fine and others who think that the expesive dedicated cables are a worthwhile investment.
If you go over to the cables forums you will read many discussion threads on these and you can make up your own mind.
In darkness a blind man is the best guide. In an age of insanity is a madman the best leader?
I'm Playing....
Astaroth is offline   Reply With Quote
Old 19-09-2005, 5:24 PM   #7 (permalink)
with 75 ohm BNC connectors on the ends. Once you start using equipment with phono connectors on (these are all 50 ohm), you can pretty much forget about impedence matching.
Old 20-09-2005, 7:09 AM   #8 (permalink)
Super Moderator
Thanks: Gave 464, Got 946
Richer Sounds were quite right, in other words.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
coax, components, richer, sounds, told
