Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 16-05-2005, 8:57 PM   #1 (permalink)
Thanks: Gave 22, Got 8
Question MY Panasonic vcr only records 2 mins!
I an=m a Brit.I have a Panasonic NV-HV60EB vcr. Recently I have on the odd occasion encountered a problem. The programme has been set to record by Video+ and under PDC as it is a BBC programme. However, when it is played back only about 2 minutes is recorded. This error so far has happened very spasmodically and I would like some advice if I am doing something wrong or what the problem might be and if I am in for an expensive repair. Could it be caused by some 'outside' influence' such as a glitch in the house's power supply? Any help will be welcome.
BTW does anyone know the current position with PDC on ITV and Channel4 as some while ago it was very patchy and unreliable?
earwax is offline   Reply With Quote
Old 17-05-2005, 10:28 AM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
Have you tried recording with the PDC switched off?
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
mins, panasonic, records, vcr
