Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Old 13-05-2005, 1:24 PM   #1 (permalink)
martin10's Avatar
Thanks: Gave 28, Got 4
Sky + and 100hz televisions
Can anybody help me ?
I am in the process of replacing an old JVC 32 inch widescreen television and want to buy either the JVC HV 32D40 ( 75hz ?? )or the 37 inch Panasonic Viera ( 50hz ?? ).
I have had Sky + since 1991 when it came out and purchased a 100hz television 2 years ago. The picture quality was poor when I linked up Sky + to it. I contacted JVC who said that the Sky + box will only work on 50hz or 60 hz televisions
Can someone confirm this or tell me if I can get around the 100hz problem with Sky +
Also what do you think about the two televisions above. Any probs with linking Sky + and a DVD player to them both via Scarts ?
Martin
martin10 is offline   Reply With Quote
Old 13-05-2005, 2:20 PM   #2 (permalink)
Thanks: Gave 69, Got 316
Well I've been working with TV's for 40 years, and I've never heard of a 75Hz TV !
Don't worry, both of these TV's will work with Sky+
All you have to decide is whether you want plasma or CRT.
Nick_UK is offline   Reply With Quote
Old 13-05-2005, 3:09 PM   #3 (permalink)
Thanks: Gave 51, Got 480
JVC's DIST televisions are all 75Hz.
Back the original question, the main reason that Sky sometimes don't recommend 100Hz TVs is they they tend to show up the digital artefacts in Sky transmissions more than 50Hz sets.
GaryB is online now   Reply With Quote
Old 18-05-2005, 1:25 PM   #4 (permalink)
bs9292
Posts: n/a
Gary - You say that Sky sometimes don't recommend 100Hz TVs but presumably the difficulty you have highlighted is a potential problem for all 100Hz TVs all of the time: a 100Hz user is peculiarly at the mercy of the quality of the Sky signal.
Have you any idea of how ubiquitous the problem is? Is it enough of a problem that members would be advised to shy away completely from the 100Hz/Sky combination?
Old 18-05-2005, 1:44 PM   #5 (permalink)
The low bitrate that Sky use can give MPEG arefacts on anything with fast moving picture content. Unless you can pursuade Mr Murdoch to put picture quality ahead of profit (which is unlikely), you can't do much about this.
Virtually all 100Hz TVs have problems with fast moving picture content. This usually shows as smearing on fast moving pictures and pixelisation, among other things. Some people are sensitive to this, some don't notice it. When you use a 100Hz TV with Sky, it tries to process the MPEG artefacts as picture content, which makes things even worse.
Since you can't do much about the first problem, you can try switching off all of the digital trickery to help with the second. If this doesn't work, a 50Hz set may be the only solution.
Old 19-05-2005, 9:35 PM   #6 (permalink)
chedmaster's Avatar
Thanks: Gave 38, Got 33
can't you switch 100hz tvs to 50hz?
chedmaster is offline   Reply With Quote
Old 19-05-2005, 9:51 PM   #7 (permalink)
Some 100Hz sets claim to be able to switch to 50Hz but they still process the information digitally. It is the analogue - digital - analogue conversion process that introduces the nasties with Sky (and Freeview) and this is still active on all the sets I have seen, even in 50Hz mode.
Old 21-05-2005, 3:30 PM   #8 (permalink)
safin
Posts: n/a
Hi.
Not sure if this is going to be of any help to you regarding the digital artifacts but this was my own experience.
I have a B&O Beovision3 32" and when I first got it home and plumbed in my dvd and freeview(via scart) the digital artifacts that you mention were very prominent,especially on fast moving pictures. Analogue signals were perfect but digital were,shall we say, annoying to say the least.
I did some digging around on B&O forums and discovered that my tv had a 'film mode' in the menu which enhances the digital pictures somehow but also seemed to cause the artifacts. By going into the service menu and turning this feature OFF it elimated 99% of the artifacts immediately.There was no appartant deterioration in picture quality and I also read this does not make the tv 50hz.Please dont ask me to be any more specific on the fine details of how it works, its all a bit techinical for me! I still notice on freeview that some channels are better quality than others, I guess this is down to the band width that is mentioned above.Do you get the problem with dvd?
Maybe your tv has a similar mode hidden in it somewhere? My B&O has a high end phillips tube, not sure who else phillips make tubes for but I guess at least a few other tv brands.
Hope this helps somehow.
S.
100hz, sky, televisions
