Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 13-05-2005, 1:21 PM   #1 (permalink)
Panasonic TV won't switch on, only switches on when button is held on....
I have an older type of Panasonic TV which is around 26" and its not widescreen or anything. This morning i tried turning it on and the light flashes, but the TV doesn't turn on unless I keep my finger held on the button and once i let go of the button, it just turns off !!!
I will be getting a new TV, but I was wondering why this has suddenly happened? Is it a minor fault that can be fixed easily? Or is just a sign that its too old and would it cost a lot to repair it?
Thanks a lot
Kev
kev269 is offline   Reply With Quote
Old 13-05-2005, 2:21 PM   #2 (permalink)
Thanks: Gave 69, Got 316
Might just be a faulty button ?
Nick_UK is offline   Reply With Quote
Old 13-05-2005, 2:25 PM   #3 (permalink)
it could be, is there anything that could be done about that? would it cost a lot to get fixed? thanks
Old 13-05-2005, 2:31 PM   #4 (permalink)
If it's an old TV, it's unlikely that a repair will be economical, when you can go to Tesco's and buy a brand-new TV for just over £200. Lots of small TV repair shops will give you an estimate, though. A lot depends on whether spare parts for that model are still available.
Old 13-05-2005, 6:33 PM   #5 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
Originally Posted by kev269
Thanks a lot
Kev
The On-Off switch is faulty............not "the button"
It should be relatively easy to repair and a lot cheaper than a new Tv. Phone around a few Tv repair shops and give them the model no and ask for an estimate.
Why did it happen? Wear and tear my friend.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 13-05-2005, 9:39 PM   #6 (permalink)
i managed to fix it so that it stays on. The only thing is that i can't turn it off now But that doesn't matter because i can still just switch it off with the remote in the meantime until i get a new TV which i need anyway
button, held, panasonic, switch, switches
