Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 11-05-2005, 9:33 AM   #1 (permalink)
TX32PD50 with Progressive Scan
I used my DVDS97 with my TX32PD50 in Progressive Scan yesterday. The picture was rubbish compared to standard interlaced. I was playing a Region 2 PAL disc, and the player can output 520p or 625p (NTSC or PAL). Both were rubbish. The colour was saturated and even the motion was juddery.
Anyone else experienced this? I guess you shouldn't use progressive with these sets.
Meeko is offline   Reply With Quote
Old 11-05-2005, 12:46 PM   #2 (permalink)
Astaroth's Avatar
Thanks: Gave 18, Got 70
I have the TX32PD30 and S97 DVD player going via component & my AVR2805. I have tried the picture both in prog scan and interlaced (though with the scaler off as i am not using HDMI) and the picture is outstanding with both and noticably better with prog scan.
I dont know why you have got an issue with your set but it certainly isnt a problem with mine. Did you have the same problem with other disks or just the one?
In darkness a blind man is the best guide. In an age of insanity is a madman the best leader?
I'm Playing....
Astaroth is offline   Reply With Quote
Old 11-05-2005, 2:35 PM   #3 (permalink)
I must admit I only tried one disc - which is a PAL region 2. Perhaps the S97 doesn't convert PAL to NTSC PS? (as the pd50 only supports NTSC PS)Although I tried the "convert from pal" on 520p and 625p and both were rubbish. Unfortunately I don't have any NTSC discs.
Do you use PAL discs with PS?
Cheers,
Meeko
Old 11-05-2005, 8:11 PM   #4 (permalink)
Thanks: Gave 27, Got 4
Cheers,
Meeko
Only supports NTSC PS??? My one seems fine and accepts PAL R2 discs in PS no problem. PQ is excellent and the set is reporting a Prg Scan input with standard Denon 1710
Display: Panasonic TH37-PX60B for cinema & LG 32LC2D LCD for games Receiver: Onkyo TX-SR605 , DVD: Panasonic DMP-BD30, Speakers: Morduant Short Premiere Plus Consoles: Xbox 360 Elite & HD DVD, Wii Media Server: Home built Win 7 Beta Media Center, Windows Home Server DVR: Sky HD
Golfpunk is offline   Reply With Quote
Old 12-05-2005, 9:13 AM   #5 (permalink)
Astaroth's Avatar
Yes, the PD30 supports PS with pal and NTSC - I would be very surprised if the PD50 didnt as it was the replacement for the PD30
I'm Playing....
Old 12-05-2005, 9:40 AM   #6 (permalink)
I do get a picture if the DVDS97 is outputting NTSC/PAL PS, so I presume the PD50 supports PAL PS, but as I said, the PQ is rubbish. The contrast settings don't seem to do anything when in progressive mode. The detailing of solid colours - i.e. skin, disappears - it looks like the display is operating in a limited colour mode, or the stream is under heavy compression. Even the motion isn't as smooth is when in interlaced. Surely this is wrong?
Old 12-05-2005, 7:41 PM   #7 (permalink)
I have compared my interlaced and PS, I can definately say PS is better. Certainly no loss in detailing. Judging by your other post Meeko, it might be your set at fault?
Old 13-05-2005, 10:34 AM   #8 (permalink)
Thanks for the information. I presume you were trying a PAL disc? I'm going to call the retailer and ask for a replacement.
Old 13-05-2005, 11:17 AM   #9 (permalink)
Brimstone's Avatar
Thanks: Gave 0, Got 2
Meeko,
I seem to remember in the 'PD30 fault list' thread that a number of people said that although PAL PS is listed on the PD30/PD50's tech list, panasonic dont gaurantee (or words to that affect) that PAL PS is supported (only NTSC PS is fully supported) - and as many people found that it didn't work on their particular TV set as those that found it did. Seems to be luck of the draw (very odd for something thats listed on the spec sheet - dunno why it happens). If you look through the thread you'll see it keeps being mentioned (if you have a spare couple of hours - its now a very long thread...). If you can still get a replacement it might be worth a try, but bear in mind that they are now discontinued and as of the last couple of weeks are rare as hens teeth to get hold of (also you might find the next set has some or many of the many common faults listed in the thread, particularly if its one of the last ones floating around panasonic warehouses). Whatever you decide or find out - good luck.
Mark.
Brimstone is offline   Reply With Quote
Old 13-05-2005, 7:46 PM   #10 (permalink)
Yes - Pal Fifth Element opera scene. Always a good test of detail and colour.
progressive, scan, tx32pd50
