Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Sony KV32FQ75 Scrolling bars!! BitchMonkey CRT Televisions 3 28-11-2003 9:11 PM
Sony KV32FX66 vs KV32FQ75 - Help Derek Mitchell CRT Televisions 8 31-12-2002 4:12 PM
Sony KV32FQ75 - Continuing Problem fwan CRT Televisions 86 27-09-2002 1:34 PM
Question on Sony KV32FQ75 Choddo CRT Televisions 0 27-08-2002 11:10 PM
sony kv32fq75 stupidmop CRT Televisions 2 07-01-2002 4:51 PM
Old 05-08-2001, 5:59 PM   #1 (permalink)
Jed Stone
Posts: n/a
Post Horizontal Wave on Sony KV32FQ75
I have just bought the above TV and am really happy with the set. However, I seem to have a feint two line wave that moves across the screen. It is most noticeable when I have Sky on channel 103 where there is just a blue screen. I also have a video and DVD connected to the TV. These are all connected with Scart leads.
Does anyone have any idea how I can erradicate this problem. IS it interference ?
Cheers in advance.
Old 06-08-2001, 8:22 AM   #2 (permalink)
Super Moderator
Thanks: Gave 465, Got 946
Post
It MAY be this.......
The TV tuner remains on even when you are watching an AV input. It stays tuned in to whatever you last had it tuned in to - presumably an analogue terrestrial channel.
The signal from the tuner is output from the Scart socket, even though you aren't watching it.
In some SCART leads (or possibly, even inside the TV) there can be some crosstalk between the Tuner singal on the output, and the video signal on the input. This crosstalk can give rise to the sort of interference you describe.
Try tuning the TV into an empty channel (one with no signal broadcast on it) before selecting AV. If it goes away, you have the source of the problem. You can then start dismantling your scart lead and disconnecting the output connections from the TV.
Scarts - yes, they are the Work of the Devil.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
horizontal, kv32fq75, sony, wave
