Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Bulb Life in rear projection tv's sycho666 CRT Televisions 1 06-12-2003 10:51 AM
Toshiba Rear Projection TV - Cheap! Greg Home Cinema Hardware Bargains and Discount Codes 2 30-08-2003 7:00 PM
I need some help on rear projection tvs kilboypowerhead CRT Televisions 10 25-02-2003 2:45 AM
Old 31-07-2001, 3:55 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Question Toshiba Rear Projection TVs
I'm thinking of buying one of the Toshiba rear-projection tvs - probably 46wh08b. I think I can get it for around 2K with all the extension speakers / cabinet etc. Can anyone recommend another set, or has any experience of the Tosh sets?
Cheers.
squiresp is offline   Reply With Quote
Old 31-07-2001, 4:41 PM   #2 (permalink)
wah
Posts: n/a
Post
Hey Pete,
My Tosh 40WH08B arrived last Friday and I have been impressed with it so far. The picture is quite bright and clear. I assume the model you're after will be the same spec apart from a bigger screen so I would recommend it - although you should check it out in the stores first before you get that credit card out.
Old 31-07-2001, 7:59 PM   #3 (permalink)
mikeaitch's Avatar
Thanks: Gave 85, Got 47
Post
Pete
Try and make sure that you shop around for prices on the 46wh, as Toshiba themselves have confirmed that the 46in will be discontinued in Sept and two new models, one 50in and one 52in with onboard digital tuner will replace it, with the 50PH18B first, in fact about now. The 52WT19B and 42WT19B are due Sept and August. Don't let this put you off the 46Wh08b- it's an excellent set- just bear this in mind when looking for a deal.
Hope this helps
Mike
JVC HD1 SKYHD EP35/KEF ref Ci2000 200c 34ds PC13Ultra Onkyo PR-SC886/RotelRB1077
HTPC: i7 @4GHz /8800GTX 6GB DDR3 5.5TB HDD LG BD/HDDVD Corsair H50 watercooling
Where DOES he get those wonderful toys?
mikeaitch is offline   Reply With Quote
Old 01-08-2001, 8:40 AM   #4 (permalink)
Jingy
Posts: n/a
Post
I have a Tosh 46" and am not happy with it at all, the picture is quite grainy but I think this is more due to the anti-reflective glass, also the build quality is questionable. As an alternative try the KP48PS1 Sony set, it is not a widescreen model but in my opinion this does not matter too much as you get 2" extra and even widescreens have black bars running top and bottom, even if it is on stretch.
Old 01-08-2001, 5:39 PM   #5 (permalink)
Post
[quote]Originally posted by Pete Squires:<br /><strong>I'm thinking of buying one of the Toshiba rear-projection tvs - probably 46wh08b. I think I can get it for around 2K with all the extension speakers / cabinet etc. Can anyone recommend another set, or has any experience of the Tosh sets?
Cheers.</strong><hr></blockquote>
You have bought your set so enjoy it. Any tv picture is only as good as the source or input. On the Toshiba you do get the best possible it is a stunning tv. Browse through the Television section on this forum and you will find many positive comments about this tv. Where you read about 'faults', you will see that in most cases it is the user who is not doing something right.
<img src="biggrin.gif" border="0">
delta is offline   Reply With Quote
projection, rear, toshiba, tvs
