Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 05-04-2005, 6:28 PM   #1 (permalink)
Philips Pixel Plus 2 Geometry HELP!!!!
I will like some help on the New 29" Philips Pixel Plus 2 TV that I bought.
The problem is that the Picture is curved at the Bottom only, I have tried to fix it by going into the Service Menu but no luck. The Picture is bent like a bow towards the ground from the edges and it seems to be a bit inwards. The fault is especially more appreciate with scrolls that run at the bottom (Like some News Channels etc)
anyone do let me know what to do, I got a 100Hz Philips Tele first got it replaced with another 100Hz Tele, both had the same problem then I got this Pixel Plus 2 tele, and it too has the same problem AHHHHHH!!!!!!!!!!!!
The picture quality on this tele is top notch , but the Gemetry Problem is not cool. What to do, should I get rid of the Philips altogether ? but what to get that matches the same quality in 29" ?
Anyways the model number is Philips Pixel Plus 2 "29PT9421/56R".
devilhimselfff is offline   Reply With Quote
Old 05-04-2005, 9:14 PM   #2 (permalink)
Thanks: Gave 90, Got 80
Originally Posted by devilhimselfff
... I got a 100Hz Philips Tele first got it replaced with another 100Hz Tele, both had the same problem then I got this Pixel Plus 2 tele, and it too has the same problem AHHHHHH!!!!!!!!!!!!...
!? what's sitting directly under the tele ?? a speaker?
Sniper is offline   Reply With Quote
Old 06-04-2005, 3:07 PM   #3 (permalink)
Hmm
Well thanks for the reply yeah there is a speaker at the bottom, and two on the side, but mmm Ive also noticed that the shape is slightly distorted at the top as well, but very slightly (if you see see a straight line)
Any help guys ?
Old 06-04-2005, 5:03 PM   #4 (permalink)
sorry to insist but - just for kicks - try moving the speakers completely away!
Old 07-04-2005, 2:45 AM   #5 (permalink)
Nope
Thanks for the reply. Hmm no no there are no speakers of Mine beneathe the TV but the Tele's own speaker (Built in) I thought you were asking about that speaker. I guess that could also cause the problem ? If not then what to do to fix this Geometry Problem ? I Have tried tinkering the Service Menu Options but it didnt help.
Old 07-04-2005, 2:12 PM   #6 (permalink)
vivaatloni
Posts: n/a
I have the same problem with my philips 32pw9509. I also noticed there is no speaker in the bottom, although it seems like there is one.
Old 07-04-2005, 2:24 PM   #7 (permalink)
Any Fix to the problem ???????
Old 07-04-2005, 7:52 PM   #8 (permalink)
Super Moderator
Thanks: Gave 464, Got 946
It's probably "within tolerance". Good geometry is actually quite hard to achieve on a large CRT. This is one respect in which the venerable CRT most emphatically does not product "the best" picture.
However, if it's new, you could always insist on an engineer's visit.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 08-04-2005, 2:55 AM   #9 (permalink)
Thanks for the reply, yeah i have got the Service Center persinals to check it out and I am insisting on getting it fixed or replaced with another Philips TV of the same Model, but then I think if 3 TV's have the same problem why wouldnt the 4th be OK, though I saw another Tele at another store that was fine, so I was thinking about getting that one but then I think that there might be something else wrong with that TV and would know only when I buy it. Do you know how this problem can be solved ? I mean the tech side. It is annoying to say the least watching that bend, and well if you are concious then it does start to get on your nerves.
Thanks for the help.
Old 08-04-2005, 2:58 AM   #10 (permalink)
I want this TV to be fixed as it is very bothersome to get it changed
Old 08-04-2005, 7:07 AM   #11 (permalink)
Super Moderator
All I can say is, it probably can be improved by service menu adjustments - factory settings are usually fairly rough - but it may well not be totally fixable. And it isn't really a job for someone untrained.
I sympathise; I can't tolerate poor geometry either. My own solution to this (and a couple of other typical issues with large CRTs) was to sell mine and buy an LCD screen.
Nigel
Old 09-04-2005, 2:48 AM   #12 (permalink)
Yeah I am trying to get it fixed by the Philips Service Personals, hopefully it might get fixed or Replaced lets see what they do in a day or two
Old 11-04-2005, 7:11 PM   #13 (permalink)
mmmm got the Other Pixel Plus 2 but mmm it has the same problem (although a bit less but still is) gonna kill myself
Old 15-04-2005, 3:28 PM   #14 (permalink)
Ok the service center guy came and he opened the set, and adjusted something attached to the Picture Tube ( A screw or something like that ) he rotated it the picture straigten ,everything seemed fine and dandy. When he left I checked the tele and the picture was bent at the top DAMMIT!!!!!! I am again waiting for the dude to visit me
Old 17-04-2005, 12:51 AM   #15 (permalink)
booker's Avatar
Hey, i got the same problem, my tv is 32PW6542 and do the same thing you are saying, it bends on both sides of the picture, it is very noticibles with scrolls or any panoramic view from side to side.
Unfortuly my cousin has the same tv and do the same thing, i browse around the forums and all this model do this as well.
I call Customer service and the Guy told this can`t be fix it, since the tv is like that
let me know if they fix this for you, ok?
so i can reclaim to them
booker is offline   Reply With Quote
geometry, philips, pixel
