Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 03-03-2005, 3:34 PM   #1 (permalink)
Thanks: Gave 3, Got 0
Help Required Buying New TV
Hi there,
First of all, apologies for my distinct lack of knowledge - I really am a novice with regards to these sort of technologies.
I've just bought a new house and am looking to get myself a new television, DVD player and audio system to go in it. Ideally, I'd like a 32" widescreen television, best value for money. I'm open to offers and advice with regards to the DVD player and audio system and how to connect them up. I have around £600-£700 to play with but could probably find some more if it's worth it.
I also have a Sky+ box and XBox I'd like to connect to the television.
Many thanks in advance,
Gav.
RaceyBoy is offline   Reply With Quote
Old 04-03-2005, 8:05 PM   #2 (permalink)
markymark34's Avatar
Thanks: Gave 36, Got 71
my advice would be have a good look through the first 2 or 3 pages of posts you will find loads of posts on decent TVs.
If its £600 - £700 for everything then its going to be tight to get a decent 32" set a dvd player (cant go wrong with tosh/pioneer (have a look at richersounds.com)) and an audio system.
go to your local electrical shop see what u like the look of and we will do our best to offer advice.
mark
Equipment Samsung 40" M86 LCD, Xbox 360, Logitech Z680 5.1 system, virgin media+ (XL TV, 10mb Broadband and finally some HD channels! ).
Other 16Gb iPhone 3GS, 30Gb ipod classic and Klipsch dock.
markymark34 is offline   Reply With Quote
Old 07-03-2005, 4:02 PM   #3 (permalink)
I now have a budget of around £1000.
I've had a bit of a look around. What do you think I should be setting aside for each component? That will give me a guideline for what kind of price range I should be looking at for each device.
Thanks for your reponse Mark.
Old 07-03-2005, 6:17 PM   #4 (permalink)
kismet110's Avatar
Thanks: Gave 508, Got 406
How about a Toshiba 32Z44 and a Denon 500SD all-in-one DVD/Audio system? The former retails for around £420 online, if you can get John Lewis to pricematch (they are currently selling it for £499) then you get free delivery and 5 year parts and labour too. One downside is no component input (which would be great as the Denon does progressive scan) but if you can live with RGB via SCART then that's not a problem
The Denon scores highly on the audio, visual and looks front and this sells for around the £400 mark too (am making plans to purchase one myself quite soon).
This leaves you £200 to spend on soemthing else!
ALI
kismet110 is offline   Reply With Quote
Old 08-03-2005, 12:39 PM   #5 (permalink)
Thank-you Kismet.
Would you recommend spending roughly equal amounts on the television and on the audio kit? I had heard good things about the Toshiba 32Z44 in terms of value for money.
I take it component input to the TV is of better quality than RBG scart. Are there any televisions in the rough price range that have component input? Is it worth trying to find one with it?
Is the Denon DVD player generally sold as multi-region?
Again, thanks for your advice.
Old 08-03-2005, 1:18 PM   #6 (permalink)
kismet110's Avatar
Generally speaking component is better than RGB but not always the case as some TV's seem to 'prefer' an RGB feed. Don't know any off the top of my head that are component-enabled AND about the same price, may be worth your while searching on this forum; as mentioned prog-scan DVD's require it so worth the effort I'm sure
Spending about the equal amount doesn't necessarily stand true, does really depend on what your priorities/preferences are; for example, you could easily spend 3K on a top plasma screen, match this with a decent all-in-one DVD/Audio system that costs a quarter of that price and be very happy with the whole setup.
The Denon is sold as multi-region by Hughes Direct and Peter Tyson, some of the others sell it R2 only.
ALI
Old 08-03-2005, 1:50 PM   #7 (permalink)
Zacabeb's Avatar
Thanks: Gave 10, Got 9
RGB and YPrPb are both component signals, even though it is the latter that is commonly referred to as component. Theoretically, the advantage of YPrPb over RGB is that it has a wider gamut, that is, color saturation is not limited by brightness as in RGB. In practice, this has little consequence as it almost never occurs.
The real-life advantages of YPrPb are that 1.) it's the native component format used for DVD Video and DTV, so the player does not need to perform conversion to RGB, and 2.) many displays use a YUV variant such as YPrPb for internal processing, in which case an RGB signal gets converted to YPrPb and then back to RGB for display.
So by using YPrPb component, you may skip redundant conversion steps and gain a bit of quality, but as a signal YPrPb is not really superior. It must be converted to RGB for display and almost always originates from an RGB source. Whether component cables perform better than the ancient SCART cable is a different story though.
Thank you Wayne Coyne, for thanking Jack White for the fiber-optic Jesus
Zacabeb is offline   Reply With Quote
Old 09-03-2005, 2:30 PM   #8 (permalink)
Thanks again for both your advice.
Well, I plan to use the television for almost everything but I'd particularly like a good picture for DVDs. I also watch a lot of football on Sky. The sound system quality is important but I don't pretend to be an audio 'connoisseur'. I would like to get a decent surround-sound experience and be able to play my collection of CDs without having to worry about poor quality.
Sorry for being a bit vague, I just want to make sure I spend my grand wisely and not pick something willy-nilly!
Is progressive scan worth going for?
Old 09-03-2005, 4:14 PM   #9 (permalink)
kismet110's Avatar
Nothing wrong with wanting to spend your money wisely, I would too, especially a large amount of it like you are!
The Denon will give you very good PQ and sound, from what I've read the CD playback is OK too. Regards football via SKY, ensure that any TV you purchase has at least one RGB enabled SCART input, switch the output in your SKY box to RGB and connect the two using a good quality fully wired SCART cable.
Progressive Scan is worth going for, bear in mind though that if you go down this route then you'll need some audio cables too as component only carries video.
ALI
Old 06-04-2005, 2:38 PM   #10 (permalink)
How to wire a Denon DHT500SD and Tosh 32Z44B
OK, I've gone ahead and ordered the Denon DHT500SD system and the Toshiba 32Z44B widescreen television. The Denon has been delivered and the Tosh is due tomorrow.
Can I ask for advice on how you would wire up the above with a Sky+ box and XBox?? Which types and makes of cable would you suggest?
Many thanks for your help so far.
Old 06-04-2005, 3:49 PM   #11 (permalink)
kismet110's Avatar
The Tosh has two SCART sockets but I can't remember if they're both RGB enabled. IF they are you can connect SKY+ to one of them and your Denon to the other (Denon has component out but Tosh has no component in).
X-Box can be connected via phono leads I presume?
ALI
Old 06-04-2005, 3:56 PM   #12 (permalink)
Thanks Ali.
If the Tosh doesn't have a second RGB scart. What would you suggest?
Old 06-04-2005, 4:51 PM   #13 (permalink)
kismet110's Avatar
Then I'd suggest using the 2nd SCART on your SKY+ box as a loop-through for your Denon. I'm pretty sure that it passes through RGB signal, if not someone will soon post to correct me.
Other option is to get a fully-wired SCART switch and feed both the SKY+ and the Denon into this then connect to the RGB SCART on your Tosh.
If you also connect the SKY+ Audio out direct to the Denon Audion in (via optical or plain phono leads) you can utilise the Denon for sound when watching SKY+.
ALI
Old 07-04-2005, 8:37 AM   #14 (permalink)
the tosh only has 1 RGB.
Old 07-04-2005, 8:53 AM   #15 (permalink)
Can anyone confirm that the Sky+ box passes through RGB signal on both SCARTS?
If not, how much are fully wired SCART switches and which retailers would you recommend?
Thanks again to you both.
buying, required
