Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 21-01-2005, 8:36 AM   #1 (permalink)
andyboy
Posts: n/a
HELP ! Can anyone suggest an alternative to JVCHV28P37SJE for £400-£450 ?
I have a JVC HV28P37SJE on order from Empire Direct and they are quoting about 2-3 weeks and I would like a new TV ASAP but I know there are problems with the JVC in terms of RGB Scart usage and Flicker on PAL Progressive.
Can anyone out there suggest an alternative set that does not suffer from these problems with the same (or close to) level of features (must inc PAL/NTSC Prog Scan) for a max of £450 ? I might stretch to £500 but would like to avoid it if possible.
Hope someone out there can help !
Old 21-01-2005, 8:02 PM   #2 (permalink)
Thanks: Gave 9, Got 24
I've seen that set for less than that somewhere. Try looking at the thread about that set as there was a price in there. Are you sure the JVC has problems with PAL progressive? I haven't seen anyone complain about that in these forums although I have seen people mention it on other TV's.
Mr_Fantastic is offline   Reply With Quote
Old 21-01-2005, 9:54 PM   #3 (permalink)
Barzo's Avatar
Thanks: Gave 66, Got 72
Agree - not the TV, the source! Pioneer 575 flickers PAL prog scan, but Tosh 340e does not. Pioneer 575 also flickers with Tosh 36P48, which has no known problems with PAL Prog Scan either. Have a look at the discussion 'Monster Head to Head' posted by Raze on the 'DVD Players' forum.
AV: Panasonic 46PZ85 Plasma TV, Onkyo TX-876, Oppo BD83 (MR), Denon DVD-3930 (MR), Toshiba EP30 HD-DVD, BTVision PVR, Humax Freesat, M-S Premiere(5.1)+ BK Gemini II sub, X-Box 360, PS3 (+PlayTV), Wii, Harmony One, Belkin PF50 PureAV
Hi-Fi: Arcam A18, Arcam CD-17, Denon TU-1800DAB, M-S Mezzo 2s
Barzo is offline   Reply With Quote
Old 21-01-2005, 10:04 PM   #4 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
JVC is about the only set at that price with component inputs...I'm afraid, there are other suppliers who may have stock, try Pricerunner http://www.pricerunner.co.uk/sound-a.../189687/prices
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
alternative, jvchv28p37sje, suggest, £400£450
