Well, RGB should be much better than composite and, according to you, on your television this isn't the case. If your sources are set to RGB and you are using good cabling, the likely conclusion is that there must be something wrong with the TV - poor QC at the big manufacturers (saving money) leads to TVs with problems hitting the market place. My own suffers from some convergence issues in the top left corner, but not bad enough for me to be too bothered about it. If mine had the sort of problem yours is suffering from though, I'd take it back.
Friday afternoon special: 70s term for items manufactured after people have had a few drinks on a Friday lunchtime; hence badly manufactured.
__________________ - TV Panasonic TX-P42V10B ▪ STB BT Vision V-Box ▪ HDD/DVD Recorder Pioneer DVR-440HX-S -
--- Console Nintendo Wii ▪ Digital Sound Projector Yamaha YSP-500 ▪ Cables Belkin PureAV ----
------- Remote Universal Remote Control Digital R50 ▪ Netbook Compaq Mini 730EA PC -------- |
