Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 20-01-2005, 5:23 PM   #1 (permalink)
dynamic turtle's Avatar
Thanks: Gave 13, Got 18
Question Best Aerial Signal-Booster Box?
The signal quality from my aerial is very poor (terrible during last night's sunspot activity). For various reasons, I cannot alter/improve the aerial or the cabling.
I'm using a cheapo signal booster that does little to improve things and was wondering if there was anything out there that can make a meaningful improvement? I.e. something that boosts the signal, rather than the noise!
Budget £100.
What make/brand do you use?
SACD: Shanling SCD-T200C or Philips DV963sa
Vinyl: Rondo Bronze > SME IV > Acoustic Signature Analogue One MkIII > Audio Research PH5 > Musical Fidelity A308cr > Usher Audio R1.2 > Amphion Xenon
dynamic turtle is offline   Reply With Quote
Old 21-01-2005, 5:33 PM   #2 (permalink)
Bumpety bump.....
Old 22-01-2005, 12:33 AM   #3 (permalink)
Thanks: Gave 21, Got 23
Talking amp
what u need is a mast head amplifer, u place a the amp box as close to the aerial feed as possible then u plug in the amplifier near the tv, this provides the curent for the amp and u are boosting the signal at its strongest point.
have a look here, scroll down get the 26db one and the power pack.
http://www.beststuff.co.uk/aerial_amplifiers.htm
there are better ones but cant think at moment.
gbmitey
gbmitie is offline   Reply With Quote
Old 22-01-2005, 1:24 PM   #4 (permalink)
Thanks: Gave 24, Got 38
Mast head amplifiers are fine to make up the loss in a long cable run.
However, the QUALITY of the signal is dependent on the specification of the aerial (gain, directivity, front to rear ratio etc).
If you don't get that right, a mast head amp will only give you more of the same.
Tight Git is offline   Reply With Quote
Old 22-01-2005, 2:12 PM   #5 (permalink)
This might be of no help if you already tried a booster:
I just bought a Philex one room aerial booster and it has worked really well with a portable labgear aerial and a On digital box. It has a variable boost screw too, it was 9.99 from Argos. It does 14Db and says its low noise.
I also saw a Philips 12Db booster for £6.97 in Asda, i didnt buy it as i just had a bad experience with their dish shaped portable aerial. Someone on digital spy recently recommended it though for improving their signal.
Oldbean is offline   Reply With Quote
Old 24-01-2005, 12:16 PM   #6 (permalink)
GB, I'm a tennant, so installing a masthead amp would be expensive and pointless, as I couldn't really take it with me if I moved again.
GB, I bought one of those £9.99 Philex/SLX2B jobbies from Maplins and they are rubbish! It wouldn't work daisy-chained with another aerial booster either
Wasted a lot of time & money so far.....
Old 24-01-2005, 4:20 PM   #7 (permalink)
Sorry DT, but you'll continue to waste time and money while you continue trying to improve an already rubbishy signal.
As I posted earlier, your problem lies at the other end of your feeder cable.
arial, box, signalbooster
