Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 20-01-2005, 3:17 PM   #1 (permalink)
Question TX-32PD50 Geomety
I've had my 32PD50 for about 2 weeks now and am generally dead impressed. DVD picture quality through component/progressive is stunning.
With Sky, however, the TV seems to have a very liberal interpretation of what a vertical line should look like (I believe that this is referred to as the picture geometry, but as I'm pretty new to all this, I'm happy to be advised otherwise!).
Instead of being straight, vertical lines are quite noticably wavey, especially at the top and bottom where they flare out towards the corners of the screen (particularly noticable with 14:9 broadcasts viewed in 16:9 format). The onscreen info box that you get with Sky also flares out at the bottom.
Is this something that I simply have to live with or is there something that I can do (or Panasonic can come out and sort for me - preferred option if it means delving into sevice menus and the like)?
Oh, and please don't tell me I should have got a 9509 - my wife preferred the look of the Panasonic, so that's that
Thanks!
shooi is offline   Reply With Quote
Old 20-01-2005, 3:36 PM   #2 (permalink)
Battlestar's Avatar
Thanks: Gave 205, Got 183
A lot of geomatry issues can be sorted out with some services menu adjustments. Unless you know what you are doing however I would ask that an engineer come and vist to sort the problem out, After all you say you have only had it a few weeks , so it should be still weel within warranty.
SOMETIMES YOU JUST GOTTA ROLL THE HARD SIX.
My DVD Collection
My youtube Channel , Take a look
PLAYSTATION NETWORK ID Galactica-Actual
Battlestar is offline   Reply With Quote
Old 20-01-2005, 4:35 PM   #3 (permalink)
Thanks: Gave 1, Got 0
Tell me about, I wanted a Sony DX200 but was overruled.
I saw this on the 32PD50 on display in a Panasonic shop, so it might well be a "feature".
Remember, if you swap it you might get one that is worse. So best to check a few in the high-street, to make sure better examples are common, before complaining.
Regards
Goggleyes is offline   Reply With Quote
Old 29-01-2005, 11:19 AM   #4 (permalink)
I have the same Geometry issues on my TX36PD50C which I received this week. I've got an engineer coming on Thursday to try and sort it out via the Service menu. Hoping it has just been set up badly at the factory.
Simcom is offline   Reply With Quote
geomety, tx32pd50
