Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 19-01-2005, 2:35 PM   #1 (permalink)
ToshTV
Posts: n/a
What's better - S Video or RGB?
Hi guys
I have currently output my Panasonic DVD player (not sure of the model) into my Toshiba 36ZP48P via a scart lead - setting the output of the DVD player and the AV3 input of the TV to S-Video.
The picture quality seems good, but would it be better if I set the DVD to RGB output using the SCART lead?
I am going to get a composite lead soon, as I have set my PS2 to composite output and the quality is superb.
Apologies for the dafteness of my request!
EDIT - The PS2 is component not composite!
Old 19-01-2005, 2:48 PM   #2 (permalink)
Thunder's Avatar
Thanks: Gave 11, Got 18
Rough order of quality
-Composite
-S-video
-RGsB/component (component is the best for DVD as its the system used for encoding the discs )
-RGBS (although let down by the rather naff scart connection method)
-RGBHV
Barco G808s, Lumagen HDP(ISF), Oppo970HD, Toshiba EP35, Tag AV32RDP, 4 ATC T16s, ATC C4CA, SVS PB12.2plus2, xbox360, 7" TFT monitor. MarkGrant cables. Toshiba Regza, Teac DRL700, Philips MT2400 HTPC, Mission FS2AV, 2 KEF 2005.2
Thunder is offline   Reply With Quote
Old 19-01-2005, 2:51 PM   #3 (permalink)
ToshTV
Posts: n/a
Brilliant - many thanks. That's some system you have there!
Old 19-01-2005, 2:58 PM   #4 (permalink)
Thunder's Avatar
Thanks very much If you wanna have a gander Im in the gallery
Old 19-01-2005, 5:14 PM   #5 (permalink)
Battlestar's Avatar
Thanks: Gave 205, Got 183
In theroey RGB is better than svideo. How ever some display devices handle the svideo signal better than a straight RGB feed and some times will give a better picture. Leads and the quality of the dvd player that out puts the signal will also be a factor.
Best thing to do is test it your self. Watch a scene of your favorute movie for 60 second in svideo, then the same in RGB , see which one you preffer
SOMETIMES YOU JUST GOTTA ROLL THE HARD SIX.
My DVD Collection
My youtube Channel , Take a look
PLAYSTATION NETWORK ID Galactica-Actual
Battlestar is offline   Reply With Quote
rgb, video
