Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 06-01-2005, 8:11 PM   #1 (permalink)
Thanks: Gave 237, Got 42
digitaldirect.com
anyoned used digitaldirect.com?
if so what us their service like?
I need to order a TV etc for my mother.
TIA
CatManDo is offline   Reply With Quote
Old 06-01-2005, 8:28 PM   #2 (permalink)
Thanks: Gave 27, Got 136
Check out their conditions if you need to a return an item for any reason......
might tell you a little about their priorities.
For that reason I look elsewhere now.
IMO, they're good if everything goes well, but no so good when things go wrong.
I ordered a TV from their sister company, Sound and Vision, and I had to exchange it. It wasn't easy or pleasant.
Some of their staff are helpful, others are certainly not and damn right rude!
Oh... and they didn't return any of my dozen or so phone calls!
For a big item like a TV, you need good after sales support if it goes wrong.
I'd consider looking elsewhere.
Oh I'm sure we can handle this situation maturely.... Isn't that right, Mr Poopy Pants?
Jules is offline   Reply With Quote
Old 06-01-2005, 8:46 PM   #3 (permalink)
Angry
I bought a 32" TV from them last year. Delivery was slow (about 10 days) even though item was in stock. TV went faulty (under warranty) and it took them 1 month and several letters before they arranged for the local service agents to collect the set (the job is subbed to a national agent and then to a local agent). Now been without the set for 4 months with no sign of it being repaired or returned. Letters to DigitalDirect go unanswered. Phone calls a waste of time. They are cheap though!
extechieman is offline   Reply With Quote
Old 06-01-2005, 8:47 PM   #4 (permalink)
Thanks: Gave 24, Got 38
Only the best for your Mother!
Repeat after me:
John Lewis John Lewis John Lewis.
And a Happy New year to CatManDo's Mum!
Tight Git is offline   Reply With Quote
Old 06-01-2005, 9:43 PM   #5 (permalink)
jtf
Thanks: Gave 1, Got 1
it seems i'm having the same probs as extechieman my tv went wrong just before xmas and after hundreds of phone calls and emails i am yet to hear from them
jtf is offline   Reply With Quote
Old 06-01-2005, 9:58 PM   #6 (permalink)
Thanks: Gave 4, Got 0
As usual a mixed bag of reviews over at Dealtime..... http://www.dealtime.co.uk/xMR-Digital_Direct~MRD-304935
HTH......
Pieman1972 is offline   Reply With Quote
Old 06-01-2005, 11:40 PM   #7 (permalink)
Thanks: Gave 1, Got 2
if you sort by lowest rating, some good horror stories
L00py^ is offline   Reply With Quote
Old 07-01-2005, 7:34 AM   #8 (permalink)
thanks for the warning guys!
think I will avoid them........might try and order from Curry's website instead.
Also my mum says thanks for the new years greetings tight git!
Cheers all.
Old 09-01-2005, 3:58 PM   #9 (permalink)
Cheers!! Just saved me from some possible aggro!!
mcguire76 is offline   Reply With Quote
Old 09-01-2005, 8:31 PM   #10 (permalink)
Thanks: Gave 14, Got 11
Angry digital direct
i bought a xp48 picture frame 2 tv back in june in october it went wrong after a week of trying to contact them they send a outside enginner to me who turned out to be 2 delivery drivers that just wanted to collect it after three weeks of waiting i finally got the tv back when i examined it they totally messed the tv up crap black level green vapour trails purity faults .i phoned digital up who presented me with a invoice for the repair,plus said the repair agent found no faults,in the end i got onto tosh direct who are dealing with it,load of cowboys i will never buy from them again.
johnboy35 is offline   Reply With Quote
digitaldirectcom
