Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 06-01-2005, 1:50 PM   #1 (permalink)
PUD the Ancient's Avatar
Thanks: Gave 238, Got 155
Panasonic PD50
Any owners out there, if so what is it like with SKY. Also is the geometry ok and do you have any other problems with the tv.Thinking about one of these as I require progressive scan but cannot seem to find a shop near me that stocks it.
PUD the Ancient is offline   Reply With Quote
Old 06-01-2005, 6:03 PM   #2 (permalink)
I got my PD50 for xmas, the picture is stunning and sky is awesome. The geometry is ok slightly noticeable. The only niggle with the set is the constant switching between aspects its like its not sure what its trying to achieve. Getting sky+ soon can't wait!
The Pink is offline   Reply With Quote
Old 06-01-2005, 7:56 PM   #3 (permalink)
Thanks: Gave 24, Got 39
Since that was one of the main complaints with the previous PD30 series, it's a pity it wasn't addressed.
Still, as more widescreen programmes are broadcast, the problem will gradually disappear.
Tight Git is offline   Reply With Quote
Old 06-01-2005, 11:42 PM   #4 (permalink)
T.G. I'm new to this widescreen game, as my previous panasonic has just given in the will to live after 8 years of loyal trouble free service.I bought my old set at about the same time the widescreen TV's were becoming all the rage, surely by now everything should be broadcast in this format. Do you know of any fixes that worked on the PD30 series that may apply to the PD50 or is it a case of just having to live with it for now. I can understand it switching the picture size between programs or when you change channels but not during a program!
Old 07-01-2005, 8:22 AM   #5 (permalink)
Have you contacted your supplier about this as the tv should only switch aspects when the broadcast changes aspect ?
Old 07-01-2005, 11:29 AM   #6 (permalink)
Thanks: Gave 13, Got 13
if your set your STB to output in widescreen, and set the Panny to 16:9 (instead of Auto), then it shouldn't be a problem... Well, it's not on my PD30! (with ntl STB)
RohanM is offline   Reply With Quote
Old 07-01-2005, 11:49 AM   #7 (permalink)
Originally Posted by RohanM
if you set your STB to output in widescreen, and set the Panny to 16:9 (instead of Auto), then it shouldn't be a problem... Well, it's not on my PD30! (with ntl STB)
RohanM,
This has been discussed ad infinitum, but if you lock the TV to widescreen then non-widescreen pictures are distorted.
Whether you prefer that to the switching is, of course, down to personal preference.
The Pink,
It's going to take a long time before all programmes are broadcast widescreen.
(Just think about colour, which has been available for more than 35 years. Sgt Bilko is still in black & white!)
I've found the main problem is when the programme is widescreen but the adverts are not. With some of the Sky cricket broadcasts you get switching every few minutes.
Old 07-01-2005, 12:23 PM   #8 (permalink)
Surely the auto switching should work correctly and if it does not it is a unacceptable fault and should be fixed by panasonic ?
Old 07-01-2005, 1:42 PM   #9 (permalink)
I'M italian, what's the problem, i don't' understand the english language very good, but i would like to buy this tv or toshiba or Jvc for to see sky, dvd and play with consolle actually and future (ps3 -xbox2) in progressive scan?
Do you explain in italian the problems of this tv, please? Thank you.
zlatan-italian is offline   Reply With Quote
Old 07-01-2005, 7:30 PM   #10 (permalink)
The auto-switching is working correctly, or to be more precise, it's working as it was designed to do.
It's the EFFECT of the auto-switching which some people find disturbing.
Old 13-01-2005, 2:05 PM   #11 (permalink)
Thanks: Gave 1, Got 0
The Pink:I'm curious as to why yours is constantly switching between aspect ratios - is it because you've got the Aspect ratio switched to "Panasonic Auto"? My PD30 works fine. Try chaning it to 4:3 (as long as you're on a 4:3 channel). This assumes that you have a Sky digibox connected via a SCART lead:
Try switching to a 4:3 channel, e.g. Sky News. Change the setting of aspect ration to 4:3. Now select a 16:9 channel, e.g. BBC News 24 and it should still auto-switch (due to the fact that status pin 8 on the SCART plug changes voltage)
dAVefaulkner is offline   Reply With Quote
Old 13-01-2005, 6:59 PM   #12 (permalink)
Thanks: Gave 2, Got 3
Originally Posted by Tight Git
RohanM,
I haven't noticed any loss of quality on my PD30 and I have it set to wide not auto.
James M is offline   Reply With Quote
Old 13-01-2005, 7:37 PM   #13 (permalink)
Just to clarify, James.
Locking the aspect ratio to "wide" will, of course, produce the correct display of a widescreen broadcast.
It's watching a 4:3 broadcast when locked to "wide" that causes distortion, with everybody short and fat, since the whole picture is stretched to fill the screen.
With the aspect ratio set to "auto", widescreen is correct and 4:3 slightly stretched each side (which most people find an acceptable compromise).
However, the height tends to jump up and down with picture content, which some people find very disturbing.
Old 13-01-2005, 7:56 PM   #14 (permalink)
MarkGixer6
Posts: n/a
Hello all. I'm new to this forum, but am interested in upgrading my existing TV (JVC AV28WFT1EKS) where do they think these damn models names up!
to the Panasonic TX-32PD50.
The main reason is that it has (I think) Component inputs (for the DVDR). Anyone know how much better this looks than an RGB signal? I was wondering whether to wait for HDTV to take off and buy a 720p set, but that could be ages, and v. pricey.
Having said all this, I think the picture on my 'old' JVC is pretty good, but only has 1 RGB scart input.
Are there any other decent alternatives out there for about £800-£900 that I should look at?
Old 14-01-2005, 2:54 AM   #15 (permalink)
Steve_P's Avatar
Thanks: Gave 67, Got 70
Although not a true HDTV (e.g. no HDMI or DVI), the tube on the PD50 has 833 lines as opposed to the PAL standard of 625.
S.
TV: Panasonic TH-37PE30B 5.1: Sony SA-PSD5 DVD: Panasonic DMR-E500H Digibox: Samsung 2100C Virgin
PC: Philips 11NB5800 (Vista Ultimate) Console: PS3 (UK,60Gb) ICE: JVC KD-AVX33 Mobile: Nokia N82 Black
Member of the AVForums Folding@Home Team
Steve_P is offline   Reply With Quote
panasonic, pd50
