Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 05-01-2005, 2:18 PM   #1 (permalink)
JVC service menu help
I have a JVC AV28T77SK. When watching widescreen programmes thru sky digibox the bottom of the screen is cut off e.g. bottom of infobar on sky sports football matches, bottom 2 answer choices on ITVs Who Wants to be a Millionaire - very frustrating
Does the answer lie in me making adjustments within the service menu? Any help would be really appreciated.
Birtie is offline   Reply With Quote
Old 05-01-2005, 5:16 PM   #2 (permalink)
Thanks: Gave 50, Got 479
Indeed it does. press "i" and Audio Mute to get to the Service Menu. You need Option 4 DEF(lection). Adjust V size to get it right. I suggest you write down the old values first in case you get it wrong. If you do get it wrong, exit without saving and try again.
GaryB is offline   Reply With Quote
Old 06-01-2005, 9:02 AM   #3 (permalink)
Thanks GaryB, problem sorted
jvc, menu, service
