| Sony 32F70U - a couple of quickies
My handbook says for Scarts 1 and 2:
21 pin scart connector including audio/video input, RGB input, TV audio / video output
Does this mean that I can use an RGB only scart to connect to the DVD and route the audio digitally to the amp?
I don't use an aerial and only get sources from the extensions - is there any way I can either remove or disable the standard aerial input as the TV always defaults to this when I turn it on and is very annoying
