Yes, I think you will find, if watching analogue then, that this will be the norm occasionally - so I wouldn't worry about this - as I say - an old 4:3 Sony Set used to do this sometimes - it was annoying at times, but definately wasn't a fault- it's just usually a slight drop in signal.
As for Freeview? Well, I have a Goodmans box - i purchased it from Argos (if you look in the current catalogue its the only Goodmans box for £49.99)
So far I have found it excellent and a lot better and sturdier made than some others I have seen (like a Nokia and Thomson box)
It's got twin scarts (which you will need to connect a VCR/DVD recorder to) and a timer as well as the BBC interactive red button thingy. It's also got a handy reset button on the back (which I have noticed alot don't have) which can come in useful at times....
Overall, I am very impressed with it, so personally, I would go for something like this. At £49.99 you can't really go wrong - and, as I say - it's got everything you need (oh - apart from a "Top Up TV" slot - which I am not remotely interested in!!!!)
Hope this helps
Cheers mate
Paul
