Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 17-11-2004, 12:55 PM   #1 (permalink)
Scirocco
Posts: n/a
Loewe VGA module
I have a Loewe Aventos with a VGA module installed. After playing around with Powerstrip a bit I have got the TV to sync perfectly with 640x480p@60 Hz, 840x480p@60 Hz, 720x576p@50 Hz and 1024x576@50 Hz. Great support for PAL and NTSC then, but the low refresh rates mean some very noticeable flicker. I have also tried some interlaced resolution and managed to get the TV to sync perfectly at PAL resolution at 50 Hz. It then seams like the TV upconvert the signal to 100 Hz, but because the DMI controller is deactivated over VGA some flicker still appears. And also, no progressive scan of course..
After playing a lot with Powerstrip I eventually got the TV to sync at 720x576p@70 Hz, but didn't manage to get a steady picture. Does anyone know of any refresh rates higher than 60 Hz that the TV support (at progressive scan)? Would be grateful for any replay regarding this topic.
Old 02-01-2005, 12:45 AM   #2 (permalink)
Loewe VGA upgrade
Your answer is here: http://www.htcentral.net/forums/index.php?showtopic=500
Regards
vascovaz is offline   Reply With Quote
loewe, module, vga
