hi m8,
Right service menu instructions as follows. First change to one of your av inputs eg: av1.
1: open the sound settings menu and put bass to highest setting (all the way up) and treble to lowest (all the way down), then exit sound setup.
2: Drop the front panel down on the tv (where the svid connector is)
3: Hold the -v button on the front of the tv and on the remote press (Index / CH.Search) button which is located just under and between the yellow and green buttons.
You should get a menu.
Once in the service menu use the coloured buttons on the remote to navigate. They are as follows.
Green = move menu item to next
Red = move menu item back
Yellow = decrease setting
Blue = Increase setting.
IF you mistakenly change something just move to the next or pevious item and it will reset the change to what it previously was.
To exit the service menu lift the flap on the remote and press the (N) key. If you start playing around and want to save changes to anything you will need to press the (STR) button under the flap on the remote to save changes.
Be careful though, don't do what i done and make changes and save them without writing down the original values first.
Finally can you post back what the following values are set to.
High red, high blue, low red, low blue, low green. Can you also see what your sub bright setting is (I haven't changed mine but would be interested to see what yours is set to).
Thanks again.
Dave
