Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 16-11-2004, 9:15 PM   #1 (permalink)
venezolano
Posts: n/a
Any tuner with components output?
Readed recently about Philips DVD-R 745, but I don't want a recorder at the moment.
Philips DVD-R 745
Do you know about any standalone tuner for dtt with component video out?
Regards
Juan
Old 16-11-2004, 9:23 PM   #2 (permalink)
MartinImber's Avatar
Thanks: Gave 13, Got 24
Netgem Iplayer
Martin - Sony KDL46W4500, STRDB930, SLHF950 SuperBeta, Pioneer 575, Castle Pembroke, Keep, & Clydes, Pace Twin PVR, BTVision. Sony TRV33 video camera. PS3
MartinImber is offline   Reply With Quote
Old 16-11-2004, 9:41 PM   #3 (permalink)
venezolano
Posts: n/a
Martin,
Thanks for the info but I've been seeking for tech spec. Hope doesn't have components output, but two SCART's.
Juan
Old 16-11-2004, 10:21 PM   #4 (permalink)
Thanks: Gave 86, Got 226
As Martin said Netgem iPlayer can do component out (via the TV scart - RGB/Component is selectable in the menu).
Rob.
Rob100 is offline   Reply With Quote
Old 16-11-2004, 11:10 PM   #5 (permalink)
The Netgem is the only seperate non PVR box I'd recommend (apart from cheap Pace) as it does component and can take a CAM.
Old 16-11-2004, 11:23 PM   #6 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
BT branded Iplayer is/was £64.50!!! you need a special scart cable thats all.
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 17-11-2004, 12:10 AM   #7 (permalink)
venezolano
Posts: n/a
Thanks to all. Do you know if there would be any problem in Spain or should work as any other dtt tuner?
Regards
components, output, tuner
