16-10-2004, 11:08 AM
#1 (permalink)
| | New Member
Thanks: Gave 0, Got 0 | Panny TX-32DTX10??? ANY PROBLEMS???
Planning to buy Panasonic TX-32DTX10
Found it for £629 at digital direct, any major probs with it
any advice would be much appreciated
16-10-2004, 12:29 PM
#2 (permalink)
| | Member
Thanks: Gave 64, Got 12 |
I've got the 28 inch version. There don't appear to be any inherent problems with it, but I've had 2 faulty ones and one with a scratched screen. I'm waiting for my 4th one to be delivered.
I'm very pleased with the picture and sound quality, which is why I'm sticking with it.
(I'm jealous that you've found the 32" version for only a few quid more than I paid for the 28 inch!).
16-10-2004, 1:42 PM
#3 (permalink)
| | New Member
Thanks a lot for your comments, sorry to hear about the trouble you've had with it, was that because of the company you ordered from? Also are digital direct reliable? and is there any problems with the 100hz refresh rate?
Any help really appreciated
16-10-2004, 3:43 PM
#4 (permalink)
| | New Member
Can anyone link me to a review of it?? i've looked all over the web
16-10-2004, 4:30 PM
#5 (permalink)
| | Member
Not sure about online reviews but What Video and Widescreen TV reviewed the 28" version a couple of months ago and I read another review in another home cinema mag (can't remember which) a few days ago.
Both said it was a good value TV and a good overall performer. The second review I saw said that background detail could be better. As I said, I'm happy with the way it performs (but I have come from a 17" TV) and none of the other TVs I've looked at have had a picture as noise free.
As for 100Hz blur, I've not had any problems on my 28" - there is blur on occasion during very fast moving scenes, but nothing like as bad as I've heard about. I even watched a footie match when I first got it (I hate footie) to test for blurring and it was fine to my eyes. You can turn off flicker reduction and noise reduction if you want (in fact, I think they are switched off by default). I keep them switched on because the picture is completely flicker and noise free with only a slight loss of sharpness.
I should warn you that all three sets I've had have taken a week or so to settle in. At first use, the picture looks a bit hazy, but it soon sharpens up with use.
16-10-2004, 4:40 PM
#6 (permalink)
| | New Member
Thanks for that mate, i'll try again for those reviews, any idea what year they are from?
16-10-2004, 4:50 PM
#7 (permalink)
| | Member
They've both been in the last couple of months.
16-10-2004, 8:19 PM
#8 (permalink)
| | Moderator
Thanks: Gave 272, Got 205 | Quote: |
Originally Posted by davidgould82 Thanks for that mate, i'll try again for those reviews, any idea what year they are from? | There is a review in this months 'What Home Cinema'.
Messages posted by me on the AV Forums are my own opinions and do not reflect the opinions or policies of the AV Forums or its associates Xbox Live - AlmeisterX |
17-10-2004, 7:40 PM
#9 (permalink)
| | New Member
What kind of experiences have anyone had with Digital Direct, as they are by far the cheapest for the 32dtx10? Any good or bad dealings with them?
19-10-2004, 8:36 AM
#10 (permalink)
| | New Member
been hearing a lot about 100hz blurring, should i forget this improved refresh rate and go for a sony 32 inch 50 hz idt
19-10-2004, 12:05 PM
#11 (permalink)
| | Moderator
Originally Posted by davidgould82 been hearing a lot about 100hz blurring, should i forget this improved refresh rate and go for a sony 32 inch 50 hz idt | IMHO if you have digitial TV (ie cable, sky, freeview) then you get this anyway on a 50hz TV.
If i watch the footy on cable bbc 1 then the picture suffers slightly from a halo effect and blocking, but if i switch over to normal aerial bbc is disappears. Although obviously aerial bbc has its only disadvantages.
19-10-2004, 12:09 PM
#12 (permalink)
| | Member
Thanks: Gave 2, Got 0 | Quote: |
Originally Posted by davidgould82 What kind of experiences have anyone had with Digital Direct, as they are by far the cheapest for the 32dtx10? Any good or bad dealings with them? | I have just bought the 28dtx1 from them - turned up about 3 days after ordering. Haven't tested the tv yet but can't fault the service so far
20-10-2004, 2:51 PM
#13 (permalink)
| | New Member
How is the sound and picture quality, if you know yet?
Probably going to order it tomorrow, any last remarks
All the best
