Hi , Recently purchased this set and reasonably happy except for two things I got used to with my 'much' older Sony set which don't seem possible on this modern set
1. OSD. If set to Minimum you don't see a volume indicator when you change volume. If set to Normal you do see the indicator BUT you are plagued with a program number that remains displayed constantly. I just want the volume indicator displayed when I change the volume
2. EXT. I'd like to assign a programme number to each of the EXT sources therefore meaning I can have single button presses to access them. Mainly so when the TV is switched on in the morning it automatically starts on the SKY channel
Philips say this ain't possible (but I have this response before on other Philips equipment (for different things) and then found solutions hidden in service menus and the like so any advise is greatly appreciated
