Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 08-07-2004, 10:29 AM   #1 (permalink)
Reset Toshiba 42wh36 - HOW?
I went into the service menu a couple of months ago and improved the convergence but think i messed around too much and want to start from scratch now.
I noted all the default settings, so was wondering to reset what i did, do i just change the current settings to the default ones?
Any help will be appreciated.
serdar13 is offline   Reply With Quote
Old 08-07-2004, 10:58 AM   #2 (permalink)
Lizzard
Posts: n/a
You can't!
You are stuck where you are...
Old 08-07-2004, 11:29 AM   #3 (permalink)
whats the point in noting down the default settings then?
if not, will try a few more tweaks to get the problems ironed out.
Old 08-07-2004, 2:49 PM   #4 (permalink)
Thanks: Gave 1, Got 32
When it comes to convergence, there are no 'default' values to write down, just grid positions on the screen..
By all means, restore any 'numbered' values back to the 'default' values you noted down before tweaking..
To 'reset' the convergence is not really possible, but if you look through the threads, you can download some 'grids' that need to be printed full size(the size of your screen) on acetate or similar, , and these allow you to line up the grid patterns exactly as the factory would...
hope this helps...
Demon is offline   Reply With Quote
Old 08-07-2004, 3:20 PM   #5 (permalink)
thats what i thought.
Thanks Demon.
42wh36, reset, toshiba
