Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 07-07-2004, 6:50 PM   #1 (permalink)
Question Purity Problems
I put up a thread a month ago with the problems I have had trying to get a 28" widescreen television. I have given up now and decide to save my money for a LCD or Plasma screen I have resorted to a Philips 25" 4:3 Television with no bells and whistles.
Now what I don't understand is why this set intermittently shows the same problems, usually on BBC 1, as all the previous 12 widescreen tv's in some way. It is most noticeable when the BBC show their red background with what programmes are on that evening. On the right side of the screen there is _sometimes_ a pink patch with a yellow patch on the left, never the other way round though.
People have said it is speakers near the TV, there aren't any now except for the ones built in. However, the purity problem comes and goes. If it was the speakers that I had near the set from the surround sound system then, correct me if I incorrect, but the purity fault would be there all the time?? Or maybe the other suggestion (from a man at the BBC) that our neighbour has a piece of medical equipment that is causing the problem, all they have is one of those automatic beds!
If anyone can help I would appreciate it.
Andy
Andy Dewhurst
lucerne20 is offline   Reply With Quote
Old 07-07-2004, 10:23 PM   #2 (permalink)
Thanks: Gave 24, Got 39
This is a strange one!
What you describe is certainly a purity problem and, as we know, purity problems are caused by magnetic objects too near the set.
The puzzle is why it comes and goes.
I can only suggest that you see what happens if the TV is used in a different part of the room (or preferably in another room).
Incidentally, I assume that you mean it comes and goes whilst you watch.
If you mean that it's ok at switch on but gets worse after a while, then that's much easier to explain!
Please let us know how you get on.
Tight Git is online now   Reply With Quote
Old 09-07-2004, 6:13 AM   #3 (permalink)
Unfortunately I have tried the sets in different parts of the room, most along one wall, but the current set we tried on the opposite corner entirely with much the same result, even to the point of only connecting the sat receiver.
(At one point I thought it may be some interference from that so I took the one from the bedroom to no avail)
Last night whilst my son was watching cbbc (Clifford etc) I noticed the pink patch move whilst my neighbour was reversing their car off the driveway! But that evening whilst watching BBC1 the patches had gone and the set hadn't been turned off for the degaussing to work.....
After a lot of sets doing the same sort of thing I am beginning to believe one of the tv engineers who said it was something about the location.
The only thing that has changed whilst all this has been going on is that the electricity company installed a new main fuse and meter, surely that can't affect it?
Andy Dewhurst
Old 09-07-2004, 10:50 AM   #4 (permalink)
"Location, location, location".
I always thought that was Estate Agents!
Well, if you've had the same problem with other sets, that would seem to be the answer.
Perhaps someone else has an idea.
The only solution that comes to mind is to move house!
Old 09-07-2004, 11:42 AM   #5 (permalink)
Thanks: Gave 51, Got 479
Purity problem can come from any ferrous metal - I've had to degauss a few radiators in my time. It can even come from magnetic rock. The current trend for converting old industrial buildings into flats has also caused a few problems. Most of them contain steel RSJs which also become magnetised over time.
If you're in a Semi-Detached or terraced house a speaker on the other side of the wall can do it.
GaryB is online now   Reply With Quote
Old 09-07-2004, 12:58 PM   #6 (permalink)
Gary B,
Agree with everything you say, but why is the purity problem coming and going?
That's the puzzle!
Old 09-07-2004, 1:51 PM   #7 (permalink)
Why it changed with the car is a complete mystery. The usual reason for varying purity is a detached shadowmask. This is the fine stell mesh just behind the front face of the tube. It's usually held firmly in place but can become detached, usually if the set has been dropped or otherwise abused. If this has happened you can sometimes hear it pinging slightly if you put an ear near the set. If it is detached, you will also usually find that the purity varies if you tap the front face of the tube.
As several sets have been tried, none of this will apply here though and, as you say, it will remain a puzzle.
Old 09-07-2004, 4:12 PM   #8 (permalink)
Maybe a daft question but how you degauss a radiator then?
Andy Dewhurst
Old 10-07-2004, 12:02 PM   #9 (permalink)
Using the same type of degaussing coil that you use to manually degauss a TV. Something like this would do the job but a bigger version makes the job easier. You switch it on, wave it all over the radiator and gradually walk away, waving it as you go. Then switch it off.
Old 10-07-2004, 3:13 PM   #10 (permalink)
Many thanks, I think the audio department at work have one of these. I'll give it a go, all else has failed........
Andy Dewhurst
Old 10-07-2004, 4:15 PM   #11 (permalink)
Just a thought. If you do suspect something in or around the house, try walking around with a compass. That should show if there is anything magnetic in the area.
Old 13-07-2004, 4:12 PM   #12 (permalink)
many thanks to all, some things I need to try.
ps. how do you close a thread off?
Andy Dewhurst
Old 13-07-2004, 6:43 PM   #13 (permalink)
I think you just edit your first post so the title reads "Solved:xxxx".
But please don't leave us all up in the air wondering what the solution is!
Old 13-07-2004, 8:20 PM   #14 (permalink)
Especially why the purity changed when the neighbour was reversing his car. I've been in this trade for 20 years and I've never heard anything like that before!
Old 12-08-2004, 6:02 PM   #15 (permalink)
Dont know why it changed with the Neighbours car, but before trying the degauss wand which arrived yesterday I thought I would give the compass a whirl. Lo and behold the pointer moved the completely opposite way, from pointing at north at the back of the house to directly at the radiator. Gave the wand a wave but to no avail, the radiator was exactly the same magnet as when I started.... I think it must of been my eyes wanting it to move. So in a nutshell I have magnetic radiators in 4 of the 6 rooms in the house........ Some plumbing to be done I think, or save up and go plasma..... Thanks again to all that gave advice.
Andy Dewhurst
problems, purity
