Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 06-07-2004, 10:57 PM   #1 (permalink)
Taz69's Avatar
Thanks: Gave 28, Got 29
Panasonic 36" TV, dropped a little bit, no its playing up, advice needed please
Hiya all,
when I was moving my 36" TV recently, my nephew dropped it as we were putting it onto the stand, it only fell a small distance, approx 5-6 inches, but now when you turn the tv off, if you want to put it back on straight away the picture doesnt appear, most times the sound is there but no picture, I have to turn it off for a while, 10mins approx then try again, most times it then works, it fell onto the right side rear of the tv if you were looking at the tv from the front, a tv chap said it could be to do with the lopt possibly being damaged by the fall, ????
any ideas please people, I do have accidental damage on my house insurance, just not sure if the tv will be repairable etc, the chap did say if it is the lopt then its stuffed, shame for such a nice tv.
Thanks in advance
Taz69
Taz69 is offline   Reply With Quote
Old 07-07-2004, 9:51 AM   #2 (permalink)
Thanks: Gave 1, Got 2
I doubt the LOPT could be damaged-maybe the solder joints on the LOPT though?? If your confident get the case off and check the PCB for cracked/damaged solder joints.If you don't knbow what you are doing DO NOT do this though!! There are some VERY dangerous voltages in there(generated by the LOPT!!!!)
DRGL is offline   Reply With Quote
Old 07-07-2004, 6:36 PM   #3 (permalink)
Taz69's Avatar
Hi m8, thanks for the reply, I dont feel up to taking the back off, not worth blowing myself away, lol, looks like I will have to get a guy out for it, the other chap still reckons its the lopt
Taz69
My Home Cinema Build http://www.avforums.com/forums/showthread.php?t=634919
advice, bit, dropped, needed, panasonic 36, playing
