Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 04-07-2004, 6:58 PM   #1 (permalink)
Test DVD
Can anybody recommend a dvd to test picture geometry with?
e.g. free with magazines or something from LucasFilm?
Thanx.
Tony_Anon is offline   Reply With Quote
Old 04-07-2004, 9:44 PM   #2 (permalink)
Thanks: Gave 0, Got 2
I use the THX Optimizer which is on Lucas DVDs (eg Raiders Of The Lost Ark, Star Wars etc) plus various others including Monsters Inc. It has tests for Contrast, Brightness, Convergence, Geometry, Aspect Ratio check etc.
Alan D is offline   Reply With Quote
Old 04-07-2004, 9:59 PM   #3 (permalink)
Thanks: Gave 19, Got 82
Also look on for the power buy section, you could pick up a DVE disk on the cheap. They are worth the extra money.
Londondecca is offline   Reply With Quote
Old 04-07-2004, 10:13 PM   #4 (permalink)
Thanks, I'll rent a THX optimizer DVD and try it out. What's a DVE disk?
How much are they? Better than THX?
Old 05-07-2004, 5:58 PM   #5 (permalink)
Digital Video Essentials. It is a comprehensive set up tool, much more detailed than the THX freebie.
Old 06-07-2004, 11:30 AM   #6 (permalink)
I found the DVE disk on Amazon.co.uk. In one of the reviews:
"However, no guidance on setting up Geometry (pincushion, trapezoid etc.) even though the test cards are ideal for this."
Is this true? I would like to set-up the geometry if possible.
Old 06-07-2004, 4:42 PM   #7 (permalink)
There are a huge amount of test patterns, if you wished to use these to alter the geometry the DVE would help but there is not a set-up chapter detailing how to do it. Maybe the risk of a person getting it very wrong is why they left it out but I am only guessing.
Might be worth looking at http://www.videoessentials.com/index.html
Old 07-07-2004, 12:37 PM   #8 (permalink)
Thanks for the link. I think I'll order it. I could always get geometry adjusted by an engineer. Having said that, maybe not with Mastercare!
dvd, test
