Originally Posted by Bigweed
Gort, how could you tell with the firmware version whether it is old or fixed?
Bigweed
Go into the "service menu" using the tv controls, hold down -VOL first then hold down -PROG, do this for 8seconds then the menu pops up.
At the top of the screen u will c the firmware version. Being an expert on this tv, since I've had TWO of em, the version will read:
Soft-ver: ITC222_V100-0
ITC22 is the chassis no.
V100-0 is firmware.
Thomson are very vague about the problems with this tv. They always tell you to return it to your retailer to be repaired, if not to contact them.
They won't admit any fault and just will say that you have a one off problem, however when I told them that I've had two faulty sets + all the guys on here with the same problems they just said they'd look into it and thank-you for informing of these "issues" - they don't like the word "fault".
Anyhow after sending that I got a repy back which was basically the same as the first email I sent them which was to return it to your retailer.
I think these letters are just picked from a list. I send another back to say again that I don't even own a Thomson tv.
You'd never guess what reply I got to that. Here is part of it.
"AS EXPLAINED BEFORE, PLEASE RETURN YOUR TV SET TO YOUR RETAILER FOR REPAIR".
I've actually send Thomson around 20 emails under different email adresses and names with different questions to catch em out.
This one takes the p.i.s.s.
I sent an email with this, "IF I BUY A THOMSON 32WB643S CAN YOU GUARENTEE THAT IT NOT HAVE THE "KNOWN" ISSUES (THEIR LANGUAGE).
This is part of the reply:
WE CAN NOT GUARENTEE THAT THE TV YOU BUY WILL NOT HAVE ANY OF THE MENSIONED ISSUES.
Not good enough, if I buy something I want it working 100%.
Everyone on here should send Thomson an email about their tv's then post their replies back on here. OR even set up a new thread.
I don't know if these tv's can be bought bug free - but if you wanna get one I woudn't take the gamble unless you know better first.
But if you get one, the bugs will spoil your enjoyment, as did me.
Hope that helps you all......
