Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 27-04-2004, 7:30 PM   #1 (permalink)
Thanks: Gave 1, Got 1
Loewe VGA card question
Now that i've decorated the front room, and have a laptop coming I can look into using my VGA card a bit more
I've got the Dreamcast running fine through a VGA box apart from one thing - no audio - is there any easy way to pipe sound in along with the picture other than using an external amp ?
Phil
Badger is offline   Reply With Quote
Old 27-04-2004, 8:15 PM   #2 (permalink)
Jack Bowyer
Posts: n/a
You bet there is....on the back I think its next to the VGA there is Audio in (3.5 socket input)...sometimes its easy to miss as its pretty hidden
I too use this method for my xbox via VGA for picture and then use 3.5 jack > 2 phono adaptor for sound.
Hope this helps....
Jack
Old 27-04-2004, 8:25 PM   #3 (permalink)
Jack Bowyer
Posts: n/a
Badger,
I would be very interested to know what resolution you can have your Dreamcast upto with your Loewe ?
Highest I can go on xbox (US) is 480p, this all depends on the games I know, but trying out a couple I have in 720p I've got no chance. My Loewe will not sync in with that res..........
Still, 480p is very clear and even more so via VGA....
Old 27-04-2004, 8:32 PM   #4 (permalink)
Hi Jack
Hi Jack - I tried the jack above the VGA socket - which is actually RC5 - but checking the manual shows me the one I should use - d'oh
The card in a Q2400 set like mine will sync to 640x480 60Hz and some WQS variants (848x480 60Hz) - the Q2500 sets will also do 640x576 at 50Hz for PAL but I don't think you can get any higher
Phil
card, loewe, question, vga
