Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 24-03-2004, 11:15 PM   #1 (permalink)
soswin
Posts: n/a
42WH36 green edge
Had to muck around with the convergence when I got this tv (got plenty of help from this forum, thanks.) I thought I had it sussed, there was a slight green edge on the right hand side of some edges but it wasnt too noticeable, however it appears to be getting worse. I can only assume I am not doing the convergence correctly although it looks ok on the various grids in the system menu. I've been following demons detailed instructions, anyone get any advice?
thanks
Old 26-03-2004, 9:23 PM   #2 (permalink)
soswin
Posts: n/a
I found this link which I think explains my problem:
http://nl.ijs.si/~damjan/edges.html
Old 27-03-2004, 3:52 PM   #3 (permalink)
Thanks: Gave 4, Got 0
SOunds like a convergence problem. In this model only the red and blue tubes can be manually converged using the normal menu. I have been having major convergence problems and tosh are going to replace it.
It is possible, I think, to adjust the green in the service mode but I haven't bothered going that far as I am getting a new one. Give Tosh a phone and see what they say, they seem to be happy to send out an engineer to do a full convergence for you.
ayrshiredude is offline   Reply With Quote
Old 27-03-2004, 6:56 PM   #4 (permalink)
soswin
Posts: n/a
I might do that. I've had 2 comet engineers out, perhaps its best to bypass them
42wh36, edge, green
