Ok, you'll have to bear with some of my character drawing attemtps at replicating a screen image, but here goes...
Originally posted by sam123
V slope
This is your tilt control. i.e. if the image slopes up or down you'd use this to correct it
V. shift - moves picture up/down ?
Yes
V. amplitude - resize picture up/down ?
Yes
Not sure what this would do.
H. shift - moves picture left/right ?
Yes
H. amplitude - resize picture left/right ?
Yes
You'd use this if the vertical lines, when viewing a 4:3 image were
(__)
or
)__(
instead of
l__l
Upper East/West corner
Lower East/West corner
Would affect how far out or into the picture the corner curved (sort of like the parabola but for the top corners and bottom
If your on screen image does this:
/__\
or
\__/
use this control to make it go
l__l
For if your screen does
\__\
or
/__/
to make it
l__l
(I think)
I would think this is the same as your east/west parabola control, except for the top & bottom edges of the picture, rather than the left & right edges...
Hope that helps, and remember, make notes of all your settings before making any changes!
