Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Old 18-02-2004, 11:14 PM   #1 (permalink)
Thanks: Gave 6, Got 0
Adjusting overscan on Sony 32FQ70
Great set but notice quite a noticeable overscan when watching DVDs. Can this be adjusted in the service menu?
Blenky is offline   Reply With Quote
Old 19-02-2004, 12:47 PM   #2 (permalink)
HowieC's Avatar
Thanks: Gave 0, Got 3
Yes, V-SIZE & H-SIZE are the adjustments you want.
Word of warning, this particular Sony chassis does not like an underscan situation which can cause a fault condition shut-down, so don't over adjust.
HowieC is offline   Reply With Quote
Old 19-02-2004, 6:49 PM   #3 (permalink)
What if I do "underscanning" ?
HowieC:
You said that if you do an "underscanning" you will cause a "fault condition shut-down". What happen if you do that mistake?? Can't you turn the TV back on then? Or is it just to turn it on again, and change the setting back??
metal82 is offline   Reply With Quote
Old 19-02-2004, 7:05 PM   #4 (permalink)
HowieC's Avatar
You would only have a problem if you reduced the picture so it was way too small, but if it did trip the protection circuits you would have a major problem.
The settings will probably need reducing by 2 or 3 points, just don't try and see how small the picture will go!!!
An remember MAKE A NOTE OF THE ORIGINAL SETTINGS.
Old 19-02-2004, 11:13 PM   #5 (permalink)
Thanks - I already found this and made some adjustments. However although I can bring in the sides it does not correct the overscan of the DVD picture. I am still losing a far chunk to the left and right. I know this because my DVD players zoom feature first zooms in and then zooms out to show the whole image nsaller than the available screen - if this makes sense! On the zoom out I can see the information that is lost.
I suspect this must be an issue with the DVD player (Toshiba SD 330E) and not the TV?
Old 20-02-2004, 2:40 PM   #6 (permalink)
Thanks: Gave 0, Got 7
Yes, it's the dvd player pixel cropping, not the tv overscanning.
bobones is offline   Reply With Quote
Old 20-02-2004, 5:47 PM   #7 (permalink)
I suppose I'm stuck with that then?
32fq70, adjusting, overscan, sony
