Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 23-01-2004, 5:33 PM   #1 (permalink)
Angry se7en and loewe (test)
I take to some time seeing failures in the reproduction of dvd in my articos.
they are devices in vertical lines (columns, lampposts, grates, etc) when there are horizontal movements.
in the film they se7en (special edition) happens of minute 2:04 to the 2:25, is the beginning of the film.
to watch in the windows of the bottom while they walk.
ah! in DMI, already that in DMM it is seen or, but one would be due to also see or in DMI.
you can prove?
pd: aconda and mimos is the same!!!
malaga is offline   Reply With Quote
Old 23-01-2004, 5:51 PM   #2 (permalink)
Thanks: Gave 49, Got 107
Try switching off both DMI and DMM - ie set the setting to OFF. Alternatively if you do wish to use DMI or DMM set DNR to off - reduces the number of artefacts.
Mark.
Pioneer 2011, Tannoy R3s, Tannoy RC, Tannoy M2s, SVS PC-Ultra13
Buckster is offline   Reply With Quote
Old 23-01-2004, 8:25 PM   #3 (permalink)
NEGATIVE
I have not paid 3000 euros to desactivate the filters.
I believe that it must of having another solution.
signal by components? the synchronism would correct it?
THANKS!
Old 24-01-2004, 2:44 PM   #4 (permalink)
Thanks: Gave 1, Got 9
Bucksters suggestion was perfectly reasonable - the extra processing modes on most sets tend to create problems while solving others. Try his suggestion of turning DMI, DMM and DNR off individually or in different combinations and see if that cures the problem - I suspect you'll find it will.
Toshiba 28HD46, Yamaha RX-V2095, Pace Sky+, Pioneer 656A, JVC HR-S6722, Sony MDS-JB980, Mission 704 front, 70c2 centre, 702 rear, Logitech Harmony 885, Philips Pronto RU940, X-Box
cerebros is offline   Reply With Quote
Old 24-01-2004, 8:31 PM   #5 (permalink)
has one loewe?
I have already proven 100 different combinations.
the problem is a failure in dmi, that I do not think to put in off.
why? because then it had looked for another television of less quality.... and more cheap.
Old 29-02-2004, 3:11 PM   #6 (permalink)
can be fault of decompression MPEG of my dvd (old jvc511)?
please !!!!!!!!!!!!!!!!!
the problem is my loewe or my dvd player !!!!!!!!!???????
Old 29-02-2004, 5:49 PM   #7 (permalink)
Thanks: Gave 6, Got 2
DMM and DMI make motion on TV and DVD look unnatural anyway so it's best left switched off.
DMM and DMI work really well with videogames though.
Loewe Xelos A37 Full HD+100, Panasonic DMR-ES25S, Xbox 360, Asian Xbox360, UK Wii, Panasonic DMP-BD35, Virgin V+ box, Toshiba HD-EP35, Philips HD1500 surround phones, Musical Fidelity X-Ray & X-A2 with Quad 12L's. Loewe Aconda 32", Asian Megadrive, PAL PSTwo, White SegaSaturn & a Telewest Digi box.
CMcK is offline   Reply With Quote
Old 01-03-2004, 10:00 AM   #8 (permalink)
CMCK: you have one loewe?
what you say on the DMM is certain but the DMI is not no filter that modify the photograms, resolution, etc. (like pixel plus)
the only thing that it avoids is the tremor of 100 Hertz
in DMI everything must go well
gracias!
loewe, se7en, test
