Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 22-01-2004, 8:53 AM   #1 (permalink)
24" Widescreen with Small Footprint
Anybody got a good one?
I was looking at the Toshiba 24Z33 but have been put off that a bit by reading a few comments on here.
Space is limited so the footprint is important.
Bettingmad is offline   Reply With Quote
Old 23-01-2004, 8:12 AM   #2 (permalink)
Totalnoobee
Posts: n/a
My parents have the Sony KV-24LS35 PQ is quite OK and no problems, its certainly much better than the Philips and Thomson alternatives they were also considering, it is a littlie bit bigger but still small.
Old 23-01-2004, 8:24 AM   #3 (permalink)
Super Moderator
Thanks: Gave 464, Got 946
Smallest footprint will be obtained from a Flat Panel. At this size, LCD is the only option. LG, Philips, Panasonic, Samsung, Sony, etc etc etc all make 22 or 23 inch LCDs. A 22 inch LCD is the same visible size as a 24 inch CRT.
They cost more than CRTs, of course. Expect to pay a minimum of around GBP900/1000 at this size.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 23-01-2004, 9:50 AM   #4 (permalink)
I don't run to 900.
I'm only human I want the ideal spec but cheap!
Old 23-01-2004, 1:51 PM   #5 (permalink)
Super Moderator
That will limit you. All 24 inch WS CRT TVs (and there isn't a huge choice at this size) are pretty much the same dimensions.
Nigel
Old 24-01-2004, 8:31 PM   #6 (permalink)
Has anyone got a Panasonic TX-24DX1? Any good?
Old 02-02-2004, 10:02 AM   #7 (permalink)
I had a change of mind and went for a Toshiba 24z33.
I've had it nearly a week and all seems OK except last night I noticed a loud buzzing noise. This occurred whenever something really bright came on screen e.g. a woman in a really bright white dress = buzzing, scene switches somewhere else = no buzzing, scene switches back to woman in really white bright dress = buzzing!
What causes this?
Old 02-02-2004, 10:15 AM   #8 (permalink)
Super Moderator
Is the buzzing sound coming from the Loudspeakers in the set, or is it originating directly from its innards?
Nigel
Old 02-02-2004, 10:49 AM   #9 (permalink)
Sounded from the innards near the back...
Old 02-02-2004, 11:24 AM   #10 (permalink)
Super Moderator
In that case, it is a line output transformer or a choke or other similar component that is being 'stressed' when the image contains a lot of brightness. CRT TVs have tended to enjoy this behaviour for as long as I can remember.
Nigel
Old 02-02-2004, 11:57 AM   #11 (permalink)
It sounds like something metallic spinning round
footprint, small, widescreen
