We would like our trusty Panasonic TX-28 PL10 (UK spec Euro 4H chassis) to be able to receive Portuguese TV which is (as I understand) PAL B/G. The TV is set up for PAL I only and cannot be easily changed (as I understand).
I came across this "
External CRT VGA PC TV Tuner Box NTSC PAL I B/G AV-In" on e-Bay for around £20 all the way from Hong Kong.
Any experience / views? Will it work or is it just too good to be true? The Panny doesn't have VGA input but can take separate S-Video and audio in which this unit seems to offer.
Frankly, the TV is worth next-to-nothing now so that's what I want to spend.
Thanks for any input.
GRC
