| Loewe aconda on the blink
Apologies for my first thread being a request for help.
My Loewe Aconda has started to play up. The colour balance is not right, black appears as purple, whites have a yeelow tinge and are too bright. Now the set has sound but no picture, just a blue/purple screen (not the blue 'no signal' screen), sometimes on start up we have had a similar appearance but green. When the set is powered down there is a multicoloured spot in the centre of the screen that slowly disappears like sets did years ago.
Having turned it off and on a few times it is working normally.
Initially I was thinking tube, I suspect the green is not functioning consistantly, in which case it is not worth repairing, however I am begining to think that some component is overheating and causing this to happen, when left off for a while it returns to normal. After 40 mins or so it is back to it's normal crisp self.
So is it likely to be a simple circuit board or similar gone which should be an easy repair, or is it likely to be something far more serious?
Any ideas folks?
