Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Sony BDP-S350/S550/S5000ES DVD Multi-region hack - all4one remote 'Forum Bike' VindalooJim Blu-ray Players 963 20-11-2009 2:39 PM
Samsung UE32B6000VW v Sony 32W5500 v ??????? DJ GA Which LCD TV Should I Buy? 13 02-11-2009 11:26 PM
EPG "Strange" issue after retune on SONY KD32DX200U Mooly Freeview 18 01-11-2009 5:18 PM
Old 01-11-2009, 11:43 AM   #1 (permalink)
sony 32 dx150 television
is it poosible to reset the television so i can clear all the current freeview channels as they are all over the place not in the correct order i would like to do a factory reset and start tuning all the channels again
the blue angel is offline   Reply With Quote
Old 01-11-2009, 2:56 PM   #2 (permalink)
Thanks: Gave 4, Got 36
Re: sony 32 dx150 television
Don`t know if there is a factory reset.But you could try a retune with no aerial connected then retune as normal.
mechanic is offline   Reply With Quote
Old 01-11-2009, 9:30 PM   #3 (permalink)
thanks for your advice worked a treat
dx150, sony, television
