Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Sony Xperia X1 - Discussion Thread Part II LFC_SL Sony Ericsson Mobile Phone Discussions 124 19-11-2009 1:51 PM
Demon's Souls (US/Asian Import Only) - Preview/Play & Help Thread Widge PS3 Games 636 14-11-2009 10:55 PM
For Sale : SONY VAIO VGN-AR51 GAMING LAPTOP Apsilon Desktop & Laptop Classified Adverts 8 27-10-2009 11:10 AM
Sony KDL-46X2000 v 46Z5500 Miller Which LCD TV Should I Buy? 7 26-10-2009 7:56 AM
Wall mount for Sony 40W5500 AnilS Flat Screen TV Brackets and Mounts 1 26-10-2009 7:44 AM
Old 26-10-2009, 8:02 AM   #1 (permalink)
Too much "Interlaced" on old Sony
I had this 10+ year old Sony 29" Trinitron, not the flat/wega series (I will look the exact model tonight). The TV produces too much interlaced lines even at long distance. Other than that is fine though, the colors still OK, geometry OK etc. For example, if the TV produces solid color (for example RED), I can see that color has very visible white interlacing lines. I hope my explanation makes sense to you . I tried to adjusting sharpness, basic brightness/contract calibration, but no luck
I also had other Sony CRT (newer model though, flat, DRC etc). I can't see flicker/interlacing lines when viewing on normal distance. I only saw them when I take a closer look on the screen.
So, I'm wondering is this normal on old CRT? if is not normal, is it hard to fix it?
tesna is offline   Reply With Quote
Old 26-10-2009, 12:55 PM   #2 (permalink)
NST
Thanks: Gave 9, Got 48
Re: Too much "Interlaced" on old Sony
Do the lines slope at a slight angle? If so, this symptom is known as flyback lines, and normally it means the tube has seen better days.
There are also a few other problems that can cause this. I'd suggest you have the TV checked by a repair company, they'll let you know if it's repairable or not.
If it is the tube, then it won't be economical to have the set repaired, as new tubes (if still available), can cost upwards of £300
NST is offline   Reply With Quote
Old 27-10-2009, 3:51 AM   #3 (permalink)
Thank you NST for the response I really appreciate it. Oh well, maybe its time to get a plasma/lcd
interlaced, sony
