Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Sharp LC-46LE700 LCD HDTV Review The News Bot AVForums Hardware Reviews 20 09-11-2009 5:35 PM
What damage can you cause by PC games on HDTV? Fennn LCD Televisions 7 21-10-2009 2:56 PM
Connecting PC to HDTV infam0us Interconnects, Speaker Cables and Switches 3 21-10-2009 12:37 AM
Not a clue which hdtv to get, budget between £500 and £600. scanz Which LCD TV Should I Buy? 3 17-10-2009 6:41 PM
Old 23-10-2009, 3:24 AM   #1 (permalink)
HDTV not 720p?
We have this exact HDTV.
http://catalog.ebay.com/Toshiba-42H8...T-TV-/48199091
Well the thing is I recently got a laptop with HD graphics and 1366x768 is its resolution.
That's obviously 720p and my laptop plays hd videos amazingly and i can really notice the reality in the images and pictures.
But my TV is 720p as well but when I connect hdmi from laptop to dvi (tv only has dvi and not hdmi), i dont get the reality images and even the colour isnt as good as watching on my laptop.
Shouldn't the images be exact?
We had work done earlier this year and I remember on the notice it said cleaning of the tv needed to be done but it was really expensive and we didnt go through, so does the tv need cleaning to be able to show 720p?
It's HDTV ready so would I need a HD tuner or something?, i just want to achieve the best picture possible out of this tv.
Ali18 is offline   Reply With Quote
Old 23-10-2009, 1:18 PM   #2 (permalink)
Chris Muriel's Avatar
Thanks: Gave 186, Got 380
Re: HDTV not 720p?
Read page 13 of the manual here :
http://www.tacp.toshiba.com/tacpasse...42h83_om_e.pdf
Not intended for use with PCs !
(You should also have posted this in the projection TV forum section not in CRTs).
Chris Muriel,
Manchester
Chris Muriel is offline   Reply With Quote
Old 23-10-2009, 10:10 PM   #3 (permalink)
Thanks: Gave 3, Got 4
Re: HDTV not 720p?
Regarding the colours, is the image too dark ? If so you might need something like the GammaX, but it really depends on each particular set.
Regarding the resolution, no 720p is not 1366x768, 720p is normally 1280x720, you might want to try to set the output of your laptop to your TV to that resolution.
JoseD is offline   Reply With Quote
720p, hdtv
