Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 04-01-2004, 1:00 PM   #1 (permalink)
J0N
Posts: n/a
Ideal viewing distances for RPTV's
Hello. I'm currently thinking about getting myself a nice new RPTV.
I'm thinking about the Tosh 42PW23P or the LG RE39NZ43RB.
My flat is not very big and my sofa is about 10ft away from the spot where the TV will have to go. Is that far enough away to make the line structure (which I can see up close to the sets when in the shops) of the screen un-noticable?
Also and advice about which of the two sets to go for would be great.
Thanks people.
Jon
Old 04-01-2004, 1:37 PM   #2 (permalink)
Kahless725
Posts: n/a
Do a search for the Toshiba model code and it will bring up loads of stuff on it. I did some reasearch when I was thinking of getting one and came to the conclusion that with a budget of arround £850 that was the model to go for. If there is anything out of line when you get it there is a wealth of info on here on how to set it up properly (the only drawback to a rp is you have to tinker every now and again to correct it)
As for the distance, I dunno, I only have about 10 foot away if I got one and I was sure that was gonna be ok.
Old 04-01-2004, 1:41 PM   #3 (permalink)
J0N
Posts: n/a
Oh yeah, do RPTV's get affected by having speakers near them in the same way as a regular CRT?
Old 04-01-2004, 5:52 PM   #4 (permalink)
Super Moderator
alexs2's Avatar
Thanks: Gave 199, Got 665
You should be fine at 10 feet with that screen size.....also,an RPTV is just as susceptible to magnetic distortion from speakers,so keep unscreened speakers well away.
My own choice was for a Toshiba,as the picture quality etc was much better than the LG's and others that I saw.
One useful thing is to take a DVD you know and like with you,and get the salesperson to hook up a DVD player direct to the TV's you want to try...much better than the shop video feed,and it certainly helped me choose.
UVEM HCPC/TEAC VRDS/AV32R-DP/LP12 Lyra Argo/Krell KMA/B&W 805/PC-Ultra/300Bs and ESLs
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
alexs2 is offline   Reply With Quote
Old 05-01-2004, 3:24 PM   #5 (permalink)
J0N
Posts: n/a
Well I've ordered the tosh and I can't wait for it to be delivered.
Sadly, due to being away with work I've got to wait until the 17th until I get my grubby little mitts on it.
I'm sure I'll be back with more questions once it arrives...
Old 05-01-2004, 7:20 PM   #6 (permalink)
jon smith's Avatar
Thanks: Gave 149, Got 115
By coincidence I ordered th LG RE39NZ43RB from Comet today and it's arriving on the 17th.
The Tosh sets are great btw, I used to have a 43 inch 4:3 one.
jon smith is offline   Reply With Quote
Old 08-01-2004, 5:50 PM   #7 (permalink)
i was looking at the LG rptv today at the comet website, have anyone seen one running....also tempted to buy a tosh..
Is a 100hz set better...
spikey is offline   Reply With Quote
Old 08-01-2004, 7:18 PM   #8 (permalink)
neilyboy
Posts: n/a
I saw an LG LCD RP running when someone else was demo'ing it. It looked very good on a DVD feed (Disney Cartoon) but I couldn't comment on its performance using other sources.
Old 09-01-2004, 3:17 PM   #9 (permalink)
F G Evans
Posts: n/a
Viewing distances
I have had the 42PW23 for approximately 4 months, I am seated approximately 7 foot away and have no problems with the picture, 10 foot should be more than enough.
The 42PW23 is extremely impressive. I bought it after looking at a few reviews on the internet, it got a couple of 5 star reviews ie best buy etc. If you look at the "toshiba web site" and find the tv there it will provide you with links to those reviews.
As for convergence issues I have had no problems yet and am more than happy relying on the ordinary user convergence controls. I would be grateful for more info on the service configuration before attempting the same.
As any one got any thoughts on the best picture settings for the 42PW23
Old 09-01-2004, 4:56 PM   #10 (permalink)
jelly's Avatar
Thanks: Gave 9, Got 8
the lg is terrible noisy picture rainbowing on dvd nasty
SAGEM HD-45F, SKY+, TOSHIBA HD E1,YAMAHA RXSL-80, X-BOX 360
jelly is offline   Reply With Quote
Old 10-01-2004, 10:57 AM   #11 (permalink)
ok!!! so theres one good and one bad comment on the LG, alot of people i've talked too have recommended the Tosh over the LG.
I fancy the 42" wide screen and my misses wants the 43" 4:3 set.
The 43" is alot cheeper, what set is recommended by you guys...
Old 14-01-2004, 3:08 AM   #12 (permalink)
42" widescreen, 100% no questions asked
Gillious is offline   Reply With Quote
Old 14-01-2004, 5:03 PM   #13 (permalink)
Thanks for that, i have now ordered a Toshiba 42PW33P from currys for £899.....and because of a product error you get the £100 stand for free. Well impressed with the demo i recieved, great pics with the dvd and satallite feed, but a bit poor with the tv feed-it was crap on all the sets though....
Old 19-01-2004, 8:47 PM   #14 (permalink)
J0N
Posts: n/a
Well I've got it (Toshiba 42PW33P) all set up now and it's awesome.
The picture quality is excellent and even the built in speakers are plenty loud enough for normal tv watching.
One very happy customer.
Picture Here.
Old 20-01-2004, 4:18 PM   #15 (permalink)
Toshiba are coming on friday to install mine, it sounds like i made a good choice....Whats the picture like throught the tv aerial....
distances, ideal, rptv, viewing
