Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 03-01-2004, 6:18 PM   #1 (permalink)
Thanks: Gave 21, Got 2
Best 24 Inch widescreen?
Not about John Lewis this time!!
My friend has just gone through a separation and in living in very small rented accommodation. The biggest TV he can fit in is a 24 inch. Advice would be appreciated on the best model to go for.
Justin
bigtired is offline   Reply With Quote
Old 03-01-2004, 9:47 PM   #2 (permalink)
electrolyte's Avatar
Thanks: Gave 1,148, Got 801
My Mum has just bought a Philips 24PW6407 for £349 from JL with 5yr warranty. Is a flat screen 50hz CRT and gives an excellent picture especially from her Sony Freeview box.
HTH
Electrolyte
Otherwise known as Simon
AV Forums Photo Competition | My photos on flickr | Simon Butler Photography | My Blog
electrolyte is offline   Reply With Quote
Old 03-01-2004, 10:08 PM   #3 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 95, Got 1,332
Sony do a decent 24" £400 ish IIRC not many around
Life's better when it's wired! - Wired Life
Proud to be an AVForums sponsor and assured advertiser
hornydragon is offline   Reply With Quote
Old 04-01-2004, 12:12 PM   #4 (permalink)
Thanks Hornydragon and Electrolyte,
Hornydragon - do you have the model number for the Sony you refer to?
Regards
Justin
Old 04-01-2004, 12:55 PM   #5 (permalink)
Assured Advertiser
No soryy saw one or 2 in currys the other day as there arent many try www.pricerunner.co.uk searching for 24" sets
inch, widescreen
