Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Your main TV - is it CRT or flatscreen? RMCF General Chat 71 07-11-2009 12:25 PM
Sky+ HD boxes and Panasonic TV's fatboy frank Sky HD 21 22-10-2009 11:44 AM
How do I connect a magic eye on my Sky HD box to my LCD TV? Bill Hicks Sky HD 3 17-10-2009 10:58 AM
HD Tv for xbox AngelEyes1 Which LCD TV Should I Buy? 3 16-10-2009 9:09 PM
Old 17-10-2009, 3:24 AM   #1 (permalink)
Thanks: Gave 2, Got 1
Can a regular CRT tv handle component?
Just wondering since if I connect a SVHS cable to my tv and select component out on my tv I get a really good quality pic compared to regular SVHS but its black and white.
And my maximum SVHS resolution is 1024x768 and with a VGA to Scart converter I can get over 1360x768 and thats officially, I have got a res of around 1600x1200 if I mess about with custom resolutions.
cherrcherryball is offline   Reply With Quote
Old 17-10-2009, 9:18 AM   #2 (permalink)
Thanks: Gave 0, Got 5
Re: Can a regular CRT tv handle component?
Can you explain a bit clearer what you're trying to do ? Are you sure you don't mean s-video, rather than SVHS ? Do you mean component 'in' on your TV or component 'out' on your source ?
I would imagine that only the more advanced CRTs with proper component inputs can handle a component signal (like my Panasonic 32PD30), but I'm no expert on the subject.
If you're trying to connect a laptop or PC to a CRT then all these higher resolutions will, of course, be unsuitable. In my experience, you'll actually have to lower the resolution to something like 800x600 (or even lower) to get a usable desktop with readable text/icons.
mikej is offline   Reply With Quote
Old 17-10-2009, 12:58 PM   #3 (permalink)
Thanks: Gave 3, Got 8
Yes a lot isn't clear.
I'm guessing that when the S-Video cable is attached (from what?) to the TV and Component Out selected (from the TV?) you're seeing, for some reason, just the S-Video Luma channel. That is the S-Video output minus the colour (Chroma).
How and why it is doing this and why it appears noticeably better than full colour S-Video I just don't know. However, I'd hazard another guess that the chances of you using this discovery to any useful purpose is nil.
fallenangle is offline   Reply With Quote
Old 17-10-2009, 7:13 PM   #4 (permalink)
I am using my graphics card on my desktop (hd4870 and q6600 pc) and selecting "force component detection" on Ati Catalyst. I think its in part regional settings as the PAL output of S video/svhs has loads of blurring and lines, and minor slowdown but if I select united states the picture is crisper with no interferance.
As for the convertor box I was talking about scrolling, the picture is crisp and clear with no interferance and proper RGB(as much as you can expect) but video movement seems to be missing say a frame or two in each bit.
Of course the text is harder to read at higher resolutions but thats not an issue since I want to use it for gaming and dvd's
Old 17-10-2009, 10:01 PM   #5 (permalink)
I think this is likely a PC/Graphics card issue and you're more likely to find somebody who really understands and, hopefully, can offer a solution if you post about it in one of the more appropriate forums here.
Old 18-10-2009, 12:42 PM   #6 (permalink)
stevefish69's Avatar
Thanks: Gave 641, Got 260
My old Panasonic TX-36PD30 gives an amazing jaw dropping picture over component. I never tried it with hooked up to my PC though apart from via S-VHS.
Funny enough it's up for grabs in the classifieds as we speak
Toshiba HD-XE1, Playstation 3 (60GB) , Marantz CD52MkII, Sky HD, PS Audio UPC-200HB
Audiolab 8000AP, Cinepro 3k6, Kef Reference 3.2, XQ2C (Bridged) , TDM-34DS, SVS PC13-Ultra & AS-EQ1
Panasonic TH50PZ80 & PT-AE3000E, 92" Harkness Hall Tab-Tensioned screen
stevefish69 is offline   Reply With Quote
Old 18-10-2009, 4:50 PM   #7 (permalink)
@stevefish69
Can try to connect it to something outputing 1080i through component ? I've found this here: Tosh 36ZP48 at 720/768i!!! (maybe usefull for PD30/50s too)
I know this is a bit late discovery but nevertheless very interesting.
User seems to suggest that the high end Toshiba Panasonic range accept higher resolutions but you have to tweak the frequencies a bit.
JonhyAV is offline   Reply With Quote
Old 18-10-2009, 7:09 PM   #8 (permalink)
Originally Posted by JonhyAV View Post
@stevefish69
Hi ya,
I did once try 720p, 1080i and 1080p through the component cables but all i got was a rolling picture that would not even attemp to lock on.
It's now in storage in my brothers spare room so i'm not able to play anymore as it's a bit heavy at nearly 90Kg to cart around
Old 19-10-2009, 8:54 PM   #9 (permalink)
Thanks: Gave 3, Got 4
@stevefish69
I got exactly a rolling pic with my Tosh when I connected it to my PC with a VGA to component adapter (must be of the type that only does color space conversion). I lowered the timings/nr. of lines of the vertical blanking interval (using PowerStrip) to lower the Khz by a few decimals and it worked! The problem is that a PS3/Blu-Ray player etc. doesn't have the option to tweak the signal. The new version of the HDFury might do it though as it has a bunch of options to tweak the signal timings. It also translates HDMI to component with inbuilt HDCP
How's the dot pitch on the set ? I discovered that the tube used in the latest Toshibas was also used in HD models in the US (maybe Australia too). I bet some Panasonic HD CRTS on the US used the same tube the PD30/50 has.
JoseD is offline   Reply With Quote
Old 24-10-2009, 2:24 AM   #10 (permalink)
Originally Posted by JoseD View Post
@stevefish69
Something like this may work for my vga to scart convertor since if I go to pal resolution like 640x576(or whatever it is) it wont work on 60hz on its own but if I change pixel rates etc it seems to stop blurring and work.
This may be a way to sort out the stuttering of normal video since I dont mind it being that res as long as theres no stuttering.
component, crt, handle, regular
