Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray Review
Scrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
What are you watching tonight/or watched last night??? Part 4 Garrett Movies and The Cinema 544 Today 5:09 AM
Recommend me some Bank Robbery/Heist Movies DVD-Man Movies and The Cinema 42 17-11-2009 4:05 PM
The A-Team movie raigraphixs Movies and The Cinema 119 11-11-2009 8:15 PM
Best "adult" scene in mainstream movie?? Woodywizz Movies and The Cinema 84 05-11-2009 11:16 AM
Old 13-10-2009, 7:04 AM   #1 (permalink)
Thanks: Gave 1, Got 0
Watching DIVx movies
Morning all,
I have recently purchased a DVD player with DIVx capability and watch them on my trusty old Toshiba 28ZD26P via RGB scart.
I have a few questions though regarding resolution and how best to display the movies. I understand that they are highly compressed .avi files and therefore when filling a 28" aren't going to look like a DVD but I seem to be having a few issues.
The DVD player I have (Toshiba SD190E) has view options such as fill, auto fit, height fit, width fit and original. When I display in original the size is scaled down into the middle of the screen and the PQ is spot on but the small size is annoying. When I auto fit, the image fills the screen and PQ not so good (understandably), however the image seems to go larger than the TV screen.
For example if there is a logo in the bottom right of the screen some of this will be cut off. It's as though the DVD player increases the size of the picture too much.
Is this a resolution issue as I would like to view the movies in 16:9 and can put up with the reduced PQ.
Many thanks
mobily is offline   Reply With Quote
Old 13-10-2009, 7:55 AM   #2 (permalink)
Thanks: Gave 1, Got 2
Re: Watching DIVx movies
Have you set the player to 16:9 or 4:3?
Cheers,
Stu
Stuart Gray is offline   Reply With Quote
Old 13-10-2009, 8:13 AM   #3 (permalink)
24 P's Avatar
Thanks: Gave 111, Got 269
you might need to use the zoom function on the dvd player or panel, I have to do this sometimes with lower resolution dvix or avis..
Sign along the dotted line........................ Some one famous (FENNN) once said: I am going to leave this question up so everybody can laugh, quite frankly I deserve NOTHING LESS than having everybody POINT & LAUGH
24 P is offline   Reply With Quote
Old 13-10-2009, 11:47 AM   #4 (permalink)
I have the DVD player set to 16:9. If I set to original the image fills the screen wide but there are huge black bars at the top and bottom.
Is it due to the resolution of the movie which I believe is something like 652 x 324 or something like that.
Does anyone else suffer this problem?
Old 15-10-2009, 5:57 AM   #5 (permalink)
I have that same problem with my Toshiba SD185EKB DVD Player and Mikomi 15LCD250 TV (a cheap 4:3 model from Argos). I'd like to always use the "autofit" mode, to scale the video to fill the whole width of the screen, as DivX / XviD videos come in a variety of resolutions (depending on the preference of whoever encoded the video). But "autofit" always results in a picture somewhat larger than the TV screen. Something I'm planning to try is to connect the player to the TV not by a SCART cable, but by "standard" video and audio cables. But I'm not putting too much hope on that.
Pedro Gomes is offline   Reply With Quote
Old 15-10-2009, 11:36 AM   #6 (permalink)
There must be a way os resolving the issue so that autofit will fit the picture to the screen and will not enlarge the image to bigger than the TV screen itself!
Old 15-10-2009, 3:28 PM   #7 (permalink)
Thanks: Gave 2, Got 3
Sounds like normal CRT overscan. You could re-encode the video to add a black border around the original, without going over the usual 720 width limit.
KBeee is offline   Reply With Quote
Old 15-10-2009, 3:35 PM   #8 (permalink)
Thanks: Gave 0, Got 2
When i have to watch 16:9 resolution i just extend it from tv.
olpers101 is offline   Reply With Quote
Old 15-10-2009, 6:49 PM   #9 (permalink)
These players being of the SD type, I think that, when "autofit" is selected, the picture is scaled to fit inside a 720x576 rectangle, while keeping the original aspect ratio. But my particular TV model can only display video up to 640x480. This probably explains why "autofit" always exceeds the screen: of the re-scaled picture, only the portion that fits in the central 640x480 rectangle is actually visible.
Old 15-10-2009, 7:50 PM   #10 (permalink)
Matt_C's Avatar
Thanks: Gave 120, Got 235
My Sony DVD player has DivX support, but is limited to displaying the film, in it's native aspect ratio, within a 4:3 "frame" - so you get black borders all around and a small picture in the middle. I can stretch this with the TV's controls, but of course, like anything zoomed as opposed to scaled, the quality suffers. Your DVD player may well also have this limitation.
A note on black borders. I saw the OP stating even when zooming the pic to full screen, that he still has black borders top and bottom. This is probably the aspect ratio of the film. Even tho the resolution of the file might be say, 1024x720, which is "full" 16:9, the original film is probably 2.35:1. On a DVD, if the aspect ratio is 2.35:1, the film is anamorphic, meaning the DVD player centres the picture, and adds the relevant black borders (basically, dead space) top and bottom.
On an AVI file, DivX, XviD etc, the file resolution is what is displayed - it's not anamorphic. So the borders have to actually be encoded into the picture, and become part of the film. It basically creates a 16:9 frame, centres the film in the middle touching each left and right side, and encodes the dead space top and bottom with black borders. So that when played back on a computer or TV, the aspect ratio is correct.
As for missing picture from the edges - this, as said, is typical CRT overscan
Samsung PS50A558 | Sony DVP-NS92V | Sony STR-DB870 | Mission M74, MD7S, AS6e | DUAL Freeview PVR | Compaq D510 "Ghetto" HTPC | iPod Video 60gb | iPhone 2G 8GB
Matt_C is offline   Reply With Quote
divx, movies, watching
