Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 02-12-2003, 7:35 PM   #1 (permalink)
IvorBigun
Posts: n/a
Question Loewe Question
Thinking of buying an ex-dem Aconda, and wondered if there was any way of checking how long it has been running for, other than just trusting what the dealer says.
Old 02-12-2003, 9:28 PM   #2 (permalink)
Oxfordman
Posts: n/a
Yes there is:
1.Open the flap at the front ot the TV and press the first button from the left. You should see the Menu "Direct control on TV", scroll down to highlight "Service"
2. With the remote on one hand press again the same button on the TV and immediately press "M" on the remote (you need to do this in 1 sec!)
3. This will open the "Service" menu. The "System Data" should be highlighted (leave all the other options well alone!!). Press OK on the remote and the Operating time will be shown in hours.
4. Press "E" on the remote to exit .
Hope this helps
Old 03-12-2003, 11:20 AM   #3 (permalink)
bobby t
Posts: n/a
IS THIS POSSIBLE ON A VITROS 6381ZW??
Old 03-12-2003, 11:28 AM   #4 (permalink)
bobby t
Posts: n/a
ITS OK - I TRIED IT - THATS VERY USEFUL! tHANKS!
Old 03-12-2003, 11:47 AM   #5 (permalink)
IvorBigun
Posts: n/a
Smile
Thanks very much, i'll give it a try.
loewe, question
